Sponsored by:
Sponsored by:
Lift Size for 35s?
Old 06-25-2013, 05:18 PM
catahoula's Avatar
Originally Posted by kh202
2.5" and cut flares is a real good set up if you are gonna be wheelin it and flexing. My 2.5" budget boost didn't rub the stock flares the few times I had it out before I cut it, with aftermarket shocks and more flex it would rub. Cut flares just plain look better too If you're just doing it for show and not flexing/ wheeling it, then you can easily run 35's with 2.5" and stock flares or probably even a 1.5" leveling kit.
Attachment 471762Attachment 471763Attachment 471764
Originally Posted by afletche
i have 35's (315/70/17 BFG AT T/A KO) and a super-cheap 1 3/4" daystar budget boost with stock fenders on a 2013 unlimited. rest of suspension is stock. it rubbed on the air dam and needed trimming just with road driving - i also did a small trim on the pinch seam. on the trails the rear rubs on the fenders and slightly on the rear bumper, and is very close to the pinch seam when flexed. i am going with flat fenders and trimming the pinch seam some more.
Attachment 471858
Nice rigs guys! I'm running 4 dr springs, TF leveling puck kit with 255's and 1.5" spacers. I know I can run 35's with that set up and might even trim fenders too. To the OP i'd look at TF 2.5" coil lift it boasts 3.1" Lots of guys running 35's with leveling kits too. Here's mine so far.
Last one I'm next to a guy with a 2.5" BB and 285's
Old 06-25-2013, 06:15 PM
Rutgyr's Avatar
If you are going to run the stock wheels, pick up some 1.5 wheel spacers. That with a budget Boost should cover your clearance issues.
Old 06-25-2013, 06:25 PM
Packrider's Avatar
I'm running stock wheels with 34s. 1.5 spacers. 2" budget lift. The only time they touch is at full lock and its just the splash shield. Soon to trim that.
Old 06-25-2013, 08:44 PM
CerOf's Avatar
If you run stock flares and bump stops and disconnect for offroad, you WILL rub, period, with any 32.5"+ tire and only a 2" lift. (32.5" is mounted height)
Proof:
Sent from some string and a few tin cans.
Old 06-26-2013, 05:43 AM
n3tfury's Avatar
Trim it? Yank that thing.
Quick Reply: Lift Size for 35s?
