Lockers: how much better are they?
Front d30 - 912A585 - $390 (Summitracing.com)
Rear d44 - 913A589 - $415 (Summit)
No air compressor, no air lines, no switches. Very hard metal though, so there may be an extra charge if they need to drill out the holes for whatever size bolts you have. If your shop can install an ARB or a detroit, they can install a truetrac.
I like the truetrac idea but how does that work with the factory brake lock traction control? They both need to sense wheel slippage to work. I would figure they may at one point work against each other.
There are a bunch of threads on this site with user feedback to look through. You will likely find comments that the bld enhances the performance of the truetrac, none that indicate it interferes. (I imagine that the owners of factory limit slips would have been raising a fuss about it for the last 8 years if that was an issue...)
I don't think I have seen any posts where anyone was unhappy about having a truetrac, other than one or two of the more hard-core types who would obviously be better served with full lockers. But that is a debate about limiteds vs lockers, not about the functionality of the truetrac itself.
And jdschup, don't let me sway you into going with aftermarket traction, or away from a full locker if that is what you decide you need. Just from your comments about your intended use, and the obvious cost savings, I think this is a good choice.
So, it seems you would say that a Truetrac is a big improvement over the stock Jeep limited slip that my JKU came with? The bottom line is that I can't afford the lockers, so, it's either staying stock or getting the Truetracs.
Assuming you are not having new gears installed, no harm in staying stock until you find a reason to not be stock anymore, or until you save enough for selectables if they would better suit your needs. You already know that it's a capable vehicle as is, and you have a winch for 'those' times...
If you are regearing, however, adding traction now would save a bunch of money, since the labor costs for gearing are about the same as for adding full case lockers/limiteds. (though the locker installs may have extra charges for drilling or mounting compressors/switches, or running lines or cables or wires, or whatever)
Yep! Going to 4.56 gears and a 2.5" AEV lift. That's what's got this whole discussion going for me.
The ARB lockers were just too much (additional $2,500 or so), so I asked for a price on Truetracs. Depending on what they say, I'll either stick with stock or go Truetrac.
We'll see!
We'll see!
Who is doing your gears? I saw a few days ago that Northridge is running a $999 gearing deal. I haven't been up to their Longmont shop yet, but may be worth a call.
And you always have the option of Eaton e-lockers and Yukon zip-lockers as well, both should save some money over arb's.
Lockers have their cons. They should be used only when really needed and should be disconnected as soon as they aren’t needed – but they are indispensable in some situations, and can make the use of a winch or being pulled unnecessary.
Front vs rear –
On steep inclines, most of the weight/pressure is on the rear wheels, so a front locker is less efficient. Vice versa on steep declines.
I’d therefore, have both, so I can either use both, or just the more suitable one.
Unless the front wheels are pointing straight ahead, or the Jeep is on slippery surface (slick mud, snow, ice, deep soft sand), lockers cause heavy strain on the drivetrain and steering.
In any other condition, I’d use them only over a short section.
However, Truetracs are, IMO, a very good second choice after true lockers.
Front vs rear –
