Looking for non-beadlock wheels with removable outer ring
#21
I have Pro Comp 1079's on my TJ. They have "Bead Lock" rings available for those and their 6079 series wheels as well. I like my 1079's except that they are tough to keep clean due to them being unsealed aluminum. If knew then what I know now, I would have had them clear powder coated when I first got them. Other than that, I like them. Just a few other options for you!
-Ryan
-Ryan
Another idea is the B.A.D. (Beadlock Assist Device) wheel. It utilizes an internal bead retention setup with removable Sacrificial Rock Rings.
http://youtu.be/9Kdt-L4r33U
#24
I also have the procomps with the "rock rings." They take a good amount of abuse, protect your wheels and are easily removed to pound them back into shape and paint. The good thing about the procomps are that they have a good high bead retention. For the past 2 years, I've routinely aired down my 37's to 8psi without any worry of breaking a bead. (as you can tell by the rear tire in this photo)
Sent from my obama monitoring device
#25
#27
What about the MB 11 wheels? They have a removable outer ring. The bolts are slightly sunk into the ring. I have them on my Jeep and love them.
Wheel Details - Discount Tire Direct
#28
I got the Level 8 Pro Trackers from Discount Tire about a month ago. Love'em, removable/paintable rock rings, two valve stems per wheel, lightweight (25lbs) and not that expensive ($190)
#29
#30
Perfect! I LOVE THOSE. ARE THE RINGS ALUMINUM AS WELL? I HOPE THERE NOT PLASTIC. THANKS
