Sponsored by:
Sponsored by:
Minimalist rear bumper suggestions.
Old 09-14-2016, 05:36 PM
srohda's Avatar
I'm looking for a minimalist rear to match the front. Any suggestions on what would look good? Click image for larger version
ID:	656839 Click image for larger version
Old 09-14-2016, 06:55 PM
afpilot82's Avatar
Evo d-rings and cover.
VKS fab
Old 09-14-2016, 06:57 PM
Jeepstin12's Avatar
I regret doing the JCR Dagger. I love the bumper, but still not good with cutting off the rear cross member. I wish I did the EVO set up. It just wasn't available then.......
Old 09-14-2016, 06:58 PM
catahoula's Avatar
Attachment 656846
VKS fab
Attachment 656847
Yup! X's 2! I'm running the EVO's and love 'em.
Old 09-14-2016, 08:44 PM
BFGMallTerrains's Avatar
Olympic rear frame cover. VERY easy to install yourself, less weight than hollow plastic stock rear, and a small fraction of the cost of most
Old 09-15-2016, 04:37 AM
Carbon's Avatar
VKS also has the EVO style D ring and Cover plate and is a lot cheaper. just sayin.
Home - VKS FabricationVKS Fabrication
Old 09-15-2016, 04:54 AM
SH0RTBUS's Avatar
Isn't it similar to the Poison Spyder BFH? That's what I run and I've been extremely happy with it. I love the departure angle! There's a certain spot where I normally go wheeling here locally where almost everyone comes down fairly hard on their rear bumper on a descent. I have yet to make contact in that spot. The original version that I have is obviously minus a hitch, but I never intended to tow aything with the JK anyway. So it's never been an issue. It's not exactly D-rings in the ends of the frame, but still pretty minimalistic. And cutting the crossmember wasn't an issue for me. The bumper pretty well takes it's place and it's much stronger.
Old 09-15-2016, 04:56 AM
Blizz's Avatar
Most bumpers I've seen with a smaller than stock footprint will require you either remove or trim the rear crossmember. I went with the Crawler Conceptz stubby bumper and love it. I completely removed the cross member but if you aren't satisfied with how securely it bolts in then you could just weld it on instead.
Old 09-15-2016, 05:58 AM
srohda's Avatar
What kind of modifications are required to install the evo i.e. cutting/drilling.
Old 09-15-2016, 05:32 PM
Bosox5's Avatar
You actually don't need to do any cutting if you prefer not to, but it looks much cleaner if you cut about an inch off frame horns. I love the setup, I can post up pics later
Quick Reply: Minimalist rear bumper suggestions.
