Mopar light bar, which size LED bar ???
#31
1 Post
Good luck, the new Mopar hoop is a great addition!!
#32
if you have the 10a front I would go with the maximus 3 light bar mounts. I think they would be a little more secure for securing the led. They will fit a 20 in bar nicely. I was going to do this but got a deal on warn hid's and went with the mounts from maximus 3. Also how was it to install the Mopar hoop on the 10 a?
#33
Not late, I'd say maybe just in time........ looks like a 20 inch bar.... what else does a guy need... wiring and switch.?? Which switch.??? Mmmmmm getting ready to make it happen....
Envoyé depuis mon MB860 avec Tapatalk
#34
20" fits perfect. You might be able to squeeze a 22" our 23" on there, but I'd have to look. My bar only came with about 2' or wire on the end of it, so I had to get some wiring and a switch. You could buy a wiring harness, but its doubtful it will reach everywhere you need it to. I made my own with 12 or 14 gauge wire, don't remember for sure. As far as switch, I used a flush mount rocker switch with red led. You can use whatever switch you want. You will need a relay as well. I have a picture off the wiring diagram I used. If you want it I'll see if I can find it for you.
#35
#36
#37
Depending on what you want out of the light is going to help you decide which route to go. I got the combo pattern LED bar, so I have great light in front, and up close/sides. But I still wanted something to really reach out a long ways, so I mounted the HID spots on my A pillars. Now I have the best of both worlds.
#39
Guys, ended going with a 20inch Cree lightbar. However, this thing only comes with a few feet of wiring, nothing else. Is there a harness with a relay and whatnot tbat I can purchase that would make installation more professional???
#40
I have purchased and just received this wiring kit from Superbrightleds,com for $20, to add some docking lights to my pontoon boat and it seems pretty good. I'm cutting the switch off and adding a factory boat switch instead, but using the rest of the harness. The harness is wired for 2 lights but you could just cut off one at the relay or just zip tie it together and out of the way for adding another light later maybe.
http://www.superbrightleds.com/morei...nel/1491/3406/
