My jeep is leaking !!!
So I've been noticing everytime it rains now my floor mats and underneath them are soaked. I've tried to find where it's coming from but there seems to be no trace. My jeep is a 2014 Jku right now I have the hard too on it. Any help is greatly appreciated.
Thanks Ryan
Thanks Ryan
Jeep has had a terrible time with seals. That being said I always kept my freedom tops in the storage bag when not in use. I had a good leak that believe it or not was caused by the white furry liner of that storage bag. You have some foam corners on those freedom tops that are a little sticky and that furry stuff works as a direct waterline into the cab. You might check yours. If not then take it to the dealer. They will replace the seals
Tons of threads on this. Mine leaks on drivers side. I removed and put silicone lube on freedom panels. Made problem get better but didn't solve. I think there is not one single cause for leaks. Some people have to send to the dealer multiple times to fix.
Jeeps leak like a MOFO. Based off my experience, your leak is coming from the the door seals, specifically the upper left corner when you are facing the door from outside the jeep. If you open your door on a rainy day, you will see a stream of water running down from the A-pillar down into the driver side floor pan. My jeep would have a nice puddle going on whenever it rained.
JK_Water_Leaks_All.pdf
Here is the JK Water leaks document showing were the leaks are and how to fix them. Everyone says its a Jeep deal with water leaks... I disagree. After a bit of work my Jeep, my wife's Jeep, and my friends Jeep are all leak free.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=634317"/> Here is the JK Water leaks document showing were the leaks are and how to fix them. Everyone says its a Jeep deal with water leaks... I disagree. After a bit of work my Jeep, my wife's Jeep, and my friends Jeep are all leak free.
