Sponsored by:
Sponsored by:
Newb wrench bumpstop and SS clamp
Old 03-23-2017, 08:56 AM
  #21
EHarris's Avatar
Originally Posted by resharp001
Dang, unless you got about 1,000 lbs of cargo in the back there.....that is some pretty bad sag. I'd replace the shocks and then reassess before addressing new springs. You may or may not determine you need them after that, but the shocks definitely sound like they're toast.
The only thing in the back during this shot is 2 surfboards and cooler of beer. Lol
Old 03-23-2017, 09:02 AM
  #22
DJ1
Former Member
DJ1's Avatar
Cooler must be made out of solid gold...
Old 03-23-2017, 09:25 AM
  #23
TheDirtman's Avatar
I have to ask why are you running so much bump stop? I did not see what size tires you are running?
Old 03-23-2017, 10:09 AM
  #24
kjeeper10's Avatar
Agree, looks like 32/33's. The TF stops are 2.75 more for a 35" tire.
Op just add a spacer if it sagging some.
Old 03-24-2017, 10:26 AM
  #25
EHarris's Avatar
I am running km2 305 70 r16. Here is my original receipt from northridge 4x4.
It was just a package deal they were selling at the time.
So is my trouble shooting to just replace the shocks in the rear first and then see how it rides?
Old 03-25-2017, 07:29 PM
  #26
EHarris's Avatar
OK so i ordered rear shocks. Should I pull the upper bump stops completely and just run the lowers? what about the front? I think there is only uppers in the front and no lowers. If the ride improves but the sag is still present I will order the 618 coils and put them in next.
Thanks for the help and advice in advance.
Old 03-26-2017, 05:36 AM
  #27
DJ1
Former Member
DJ1's Avatar
If you're running a bumpstop style similar to factory, you need that foam piece on top in addition to the lower bumpstop extension that's sized to your particular lift if I'm understanding you correctly....
Old 03-26-2017, 04:49 PM
  #28
EHarris's Avatar
If you go to the top of this thread you will see the pics I took. I'm wondering if I should replace the uppers inside of the coil. The lowers are just a solid block it looks like.
Old 03-27-2017, 06:03 AM
  #29
resharp001's Avatar
Received 1,826 Likes on 1,596 Posts
If you feel like the upper foam pieces are worn, replace those. If you pull them out you'd have metal hitting the lower bumpstop and you don't want that. The foam part shoved up in the uppers compresses quite a bit and basically just stops the metal from hitting your bump. I'd imagine those can't be too expensive to replace if they are in that bad of shape.
Old 03-27-2017, 08:28 AM
  #30
EHarris's Avatar
Ok that's exactly what I needed to know. I will replace them also. Super cheap and mine are thrashed.
I am also keeping the lower bumpstops in place. They do not look worn out since they are just blocks of rubber. They are in the picture at the top of the thread also.
So new shocks, new coils that are 618, new upper bumpstops and leaving the lowers in place. Running 305 70 r16 and hoping this solves everything.
Quick Reply: Newb wrench bumpstop and SS clamp
