Not death wobble, but its up there .. and rear springs?
Went wheeling at Evans Creek for those of you from PNW ... well very tight trails and some body damage later ....
Rear springs are pushed forward and axle is twisted. I can tell this because my diff is going the opposite way of my springs. You can't really tell in the pictures, its the best I could do, but you can kinda see the springs pushed forward .... I took front spring pics to compare too ..
SPRINGS -Does anyone else rear springs go forward? They were straight and vertical before?
----> front spring ... its actually straight unlike rear.
AXLE - trac bar isn't bent and mangeld, could it be the control arms pulling it one way? Will an alignment fix this?
Acceleration - from 5 mph to as quick as I decide to go for the day ... I am wobbling and jiggling .... its coming from the rear .. don't know if this has to do with my axle being all whacked out. But the wobble goes away when I come to a stop, and doesn't go away at all, at any speeds ... its like ugugugugugugugugugugugug ....
any ideas anyone?
any ideas anyone?
JK-Forum Founder
if you have an aftermarket driveshaft and you've set your pinion angle to be in line with it, your coils should look like that. regarding what you are feeling, have you checked your control arm bushings to see if you might have blown one or more of them? have you checked your control arms so see if any of them are bent? have you checked your wheels to make sure that your lug nuts are on tight? and maybe the first thing you should have checked - do you have mud packed in your wheels or did you maybe toss a wheel weight or two?
I haven't checked the bushings on the Control arms and they don't look twisted or bent as far as I can tell ...
Haven't checked the lug nuts yet either, I will head outside and do that ...
As for the aftermarket driveshaft .. yes I do ... I beleive the angle was set when my mechanic installed the new axles. .... can it get screwed up between wheeling and dd though?
JK-Forum Founder
