Not Happy with the Rake of my Rancho Leveling Kit
Well I didn't think that I'd have to pay $1200 for a new bumper and winch just to get it level. I guess I'll have to add another puck. It already has two, the factory spacer and a 1" rancho puck. I'd rather just have one back there instead if having 3 or 4. I guess I'll need a 3" or 4" single puck then and I'm not sure if rancho even sells those. I think teraflex does but I also don't want to mix match brands.
What's wrong with buying more stuff? Far as mixing stuff my rock krawler lift came with teraflex bump stops. It's fine to mix stuff sometimes.
Your leveling kit came with what, exactly? 2" front coils and nothing else? Or it is the full 2" sport system with front coils and rear spacers?
A spacer is pretty much a spacer, just a chunk of hard plastic or whatever. Doesn't really matter which brand you use. The plus for Teraflex rear spacers is the long prong that helps keep the coils in place.
You also need to think about other components before you go slapping 3-4" of lift on the back. The short shocks and the short brake lines and the angled down swaybar come to mind.
There are rarely two Jeeps setup the same. The aftermarket has to attempt to cover a wide variety of possible situations and setups.
I remember you posting your Jeep had sagging stock springs. A better route might be finding some rear take off springs that are lower mileage and a higher spring rate.
just put some more miles on it. The springs will settle a bit after some road use and a wheeling trip or two. Be patient and live with the rake for just a while longer.
I remember after I installed TF 1.5 springs leveling kit my 2dr JK also looked like it was taking a dump. I fixed it by installing spacers in the back. No, springs are not going to settle over time to noticeably affect the look. For once, when they do settle fronts and rears both going to settle.
The key is to decide how tall of a spacer you want to use in the back. Measure tire to fender distance in the front and in the rear. In the end the distances should be at least equal, or rear 1/4" higher, for the best looks, in my opinion.
If I recall correctly the OP's Jeep is a two wheel drive model. The suspension of a 2WD JK sits an inch lower than a 4WD. I'm sure Rancho wouldn't have set up the kit correctly for a 2WD.
What's the part number of the rear OEM spring? It should have a tag on it.
So just a few things. I dont off-road much at all, I just go out on dirt trails for the most part to get to camping areas. Yes it is a 2wd and it is an entry level Jeep for me. I bought it for 10k less than the other 4wd's that were available at the time. I have no desire to ride up rocks and such. It my DD and I do about 99.9% street driving on terrible Los Angeles streets. It feels like I'm riding a mechanical bull into work everyday so that is why I went with the recommended Rancho XL9000s because the rubicon shocks I had were too stiff.
Now with the rebate, I was able to get the leveling kit for next to nothing. I did specify that it was a 2wd when ordering and yes it did come with a rear puck that I added to the factory OEM spacer.
I just measured the space between the fender and the top of the tires and I have:
7.5 inches of space on the front
4.5 inches on the rear.
If I do that math correctly, if I take out the 1" Rancho I have in there now and want to get it level or even higher in the back, I'll need about a 2.5 to 3" spacer back there. From what I have seen, Teraflax makes a 2.5 spacer so that might be my only option unless I get bigger rear springs.
Either way, a small inexpensive upgrade is going to cost me more $$$$ and time down the line. The pucks are $120 and springs are about $200.
Right now I'm really regretting this decision that I made.
I have the Rancho 4" Sport Lift, going on 2 years now. Bigger tires, heavier bumpers, winch and no front sag at all. At first I thought the front sat up and it did compared to stock. Checking the frame I found it is now level.
I'm happy!
(Note: Reverse rake is even more pronounced in these pics because front was up hill.
I'm happy!
