Ordering Toyos 285/75...
#21
I have a 10a Rubicon with a 2.5 lift, 1.5 spidertracs and TOYO R/T open countrys 295 70r17 on stock wheels. I love these tires, they are quiet and the tread looks great. I will probably buy the same tire when these are done and these came with the 50k mile tread warranty. Couldn't be happier.
Attachment 643424
Attachment 643424
#22
I have a 10a Rubicon with a 2.5 lift, 1.5 spidertracs and TOYO R/T open countrys 295 70r17 on stock wheels. I love these tires, they are quiet and the tread looks great. I will probably buy the same tire when these are done and these came with the 50k mile tread warranty. Couldn't be happier.<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=643421"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=643422"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=643423"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=643424"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=643425"/>
#23
I researched the crap outta them! Got them recently and love them!! Was worried that I would think they were to skinny. Not at all! Pics don't do them justice!! 33.25 @35psi mounted on 17x9 pro comps
#24
Heard a lot say they look better in person.
I will admit I'm a tad leary thinking they are going to look to thin, but they are still wider then the stock KMs... So should be ok
#25
Honestly don't worry one bit!! When mounted they look great!! PLENTY wide!! With 4.75 back spacing the fronts side wall sticks out 1.5" from the front fender. The stock 255's on the stock wheel with 6.25 back spacingl were inside the fender by .75"
#26
I'm running 1.5 spacers , so I little tire sticking out is fine.
#28
You guys that are running this tire, have you done C- gussets?
I did when I had 35x12.5s, but in researching this size, no one ever mentioned beefy up the front axle. We might wheel once a year in Moab or Colorado , and it's mild stuff... Slow and easy
#29
If you don't beat on it, you will be fine. I have run these and 35x12.5-17 at2's for the last 44000 miles and I wheel a fair amount and my camber has not changed one iota from new.
