Outside window A piller bolt size
Hey guys does anybody know what size those 6 black bolts are? Thought they were a SAE since metric ones didn't match up but even the SAE ones still didn't thread properly.
I was going to install a light bar and the brackets that I have I would like to have a little longer ones so anyone know what they are?
Thanks
Thanks
I would just call the mopar parts department or go to the dealer and have them give you the specs. They probably have some bolts on hand that are a little over priced, or you can find them once you get the specs.
I'm getting the fealing that when you buy a cheap set of 50" LED light bar brackets they aren't going to fit flush against the A piller like it should
Anyone have the same issue with a cheap pair of brackets and did a more expensive ones like Riged or TF ones fit better
Is the head a torx 50? I would go to the Jeep dealer get the specs then go on Amazon a order them. The fastenal here is a joke they have to order most stuff because they have very little on hand at their store. Which makes no sense to me.
The oem ones matched up to a sae thread but not so much in the Jeep
