Popping noise....ugh!
I have an '07 Rubicon 2dr with stock aluminum 17" wheels and 32" BFG's. I put a 2.5" Teraflex coil lift on and shortly after a popping noise has manifested from what seems to be the passenger rear. My first thoughts were the track bar. I went through the rear suspension and re-torqued everything. I did noticed that the rear passenger sway bar end link had been rubbing on my wheel. The damage was acute, so I figured it had to be from my off roading trip and all the flexing and have since ruled it out. I've searched this forum but everything I've found has been on larger lifts and most problems were coming from the front.
Any input is greatly appreciated, I really don't want to take it to the dealership and here how they can't pin point the problem but you owe us $300 in check out fees.
This is normal with your lift
Your need wheel spacers, or off-set rims
Cheaper solution; remove the 2 rear sway bar links, and install it INSIDE (instead of outside) I did it and no rubbing anymore
I would say its the rear passnger coil hitting the track bar. The springs are bowed back rubbing the track bar. Alot of guys including me had the same issue. Cheap fix Rock Krawler 10 degree wedge. You have to call them 25 bucks. Expensive fix relocate the spring monts on axels.
I did the BB instead of springs and had to install an adjustable rear track bar to keep the passenger sway bar link from rubbing. I did reverse the link. Check to see if the rear axel is centered.
Last time I checked LA kits all have adjustable arms.
