Sponsored by:
Sponsored by:
Portable Air Compressor outside of vehicle mounting
Old 12-18-2016, 04:57 PM
  #21
ronjenx's Avatar
Originally Posted by jeepmojo
Ill prob just rig up a pre attached wire pair from battery
to spare me the hassle of clipping to the terminals on the battery each time.
That's what I did. The connector in the back can be used for the compressor or inverter, when needed.
Old 12-19-2016, 04:49 AM
  #22
jeepmojo's Avatar
Default there you go.
or you could even add a flush mount surface outlets if you wanted to get fancy/ even with your air hose connectors using connectors of this sort mounted in a weather proof outlet box or housing.
re photo : are those # 6 copper looks heavy duty?
Old 12-19-2016, 06:45 AM
  #23
ronjenx's Avatar
They are #4 copper stranded cables.
Old 12-19-2016, 06:57 AM
  #24
jeepmojo's Avatar
where did you get your connectors ? If you can recall . im sure they are available
in most automotive parts store but for # 4 cu might be harder to find them
Old 12-19-2016, 07:37 AM
  #25
ronjenx's Avatar
I have seen them at various auto parts stores, and on line.
Old 12-20-2016, 11:00 AM
  #26
jeepmojo's Avatar
Default Well just got the delivery on the air armor 240
first impression is pretty high quality kit . I know its not the ultimate compressor out , however it looks really nice and most likely it work well for the amount of use ill give it. And the price was perfect for what i was willing to spend . Ill do like ronjenx did and eliminate having to open the hood every time you need to use it.
it seems logical and a good idea. The hose is very pliable and long instead of the coil type. that seem to fail pretty quickly in cold temps
prob will attach a jerry can tray to the passenger side of the rear of my 2 door over the wheel well seeing i dont carry a rear seat, so it wont bounce around . Or bolt with a wingnut on inside of can to the tub rail.
Old 12-25-2016, 04:46 AM
  #27
nevrnf's Avatar
I am planning to add a compressor to my daughters jeep and I was thinking the Harbor Freight one mounted upside down inside of the tire carrier. She already has the MORryde hinge and support set up on hers and it looks like a good spot semi out of the elements. Here is the carrier we will be adding this year as she is going to 37's.
Heavy Duty JK Spare Tire Carrier | Retrofit Offroad
The pump should fit perfect inside of it. I already have a 2G wire running to the rear seat as there is an amp for the stereo. It has a distribution block so I could easily run a 4G wire to the gate to power the compressor. At $49 even if it was replaced every couple of years it would be no big loss.
Old 12-25-2016, 05:09 AM
  #28
karls10jk's Avatar
Originally Posted by nevrnf
She already has the MORryde hinge and support set up on hers and it looks like a good spot semi out of the elements. The pump should fit perfect inside of it.
I have the carrier and the room is tight in there. If you've got measurements on the pump then I'll check to see if it fits. I'm hanging a 37" on the back now.
Old 12-25-2016, 07:35 AM
  #29
nevrnf's Avatar
I don't, But I have to drive right past Harbor Freight tomorrow so I will stop and get some. From the looks of the mount it should stay relatively dry.
Old 12-25-2016, 08:18 AM
  #30
Monte417's Avatar
My old lady got me this for Xmas what you guys think?
Quick Reply: Portable Air Compressor outside of vehicle mounting
