Rattle when on gas in 4th and 6th gear
It is the transmission. I just got done replacing mine for same reason. I had a lot of metal shavings on drain plug magnet. I got a rebuilt transmission from High Gear in Tennessee.
I think I found my problem I took the boot off for the shifter . The middle boot was ripped so In 4th and 6th gear the rip got bigger . Going to put a new boot on and see if it fixed the noise
Yeah everything from the top , the boot under the man one just pops off . Then you can get to the shifter bolt in the rubber bushing mine had a little play so I used a washer on the bolt to lesson the the side to side flex . While I was there I put a rubber hose on the transfer case line where it touches the dash . And I put rubber hose on the heater core lines from inside the glove box
