Sponsored by:
Sponsored by:
RCV's or G2 Gold front shafts
Old 11-23-2015, 09:44 AM
BuckLisa's Avatar
Default RCV's or G2 Gold front shafts
I've been researching the pro's and cons of RCV's. It appears they are more "delicate" than previously thought and a tad more time consuming in lubricating them. Around $1300 or $989 for the G2 upgraded 4340 chromoly traditional shafts. Anyone with experience chime in to help me?
Old 11-23-2015, 10:13 AM
Invest2m4's Avatar
I don't think I know of a broken RCV in a JK. Lubricating takes a couple min and isn't that often. I wouldn't factor that. What is time consuming is breaking u-joints on the trail. It is nice with the RCV knowing you can have the wheels turned while jammed in some rocks and that you won't be blowing a joint.
If you are going to keep u-joints in the front, I wouldn't even bother upgrading the shafts.
Old 11-23-2015, 10:47 AM
pontiac31's Avatar
^^^what invest said. Upgraded shafts accomplish little when a u joint gives and ruins the ears.
Old 11-23-2015, 11:35 AM
BuckLisa's Avatar
Do the RCV's now come with the lube nipple on the end of shaft as standard now?
Old 11-23-2015, 01:08 PM
Invest2m4's Avatar
It uses a needle grease tip on the grease gun. you don't use a zerk on it. No need.
RCV Needle Grease Tip
You can buy those at any parts stores.
Old 11-23-2015, 06:03 PM
Biginboca's Avatar
Greasing the RCV's is as simple and quick as can be if you don't have center caps. Just push the needle into the end of the shaft give a few pumps and done. It actually took me longer to write this than to grease both shafts.
Old 11-24-2015, 07:56 AM
kjeeper10's Avatar
At least tack the caps in place.
Old 11-27-2015, 09:42 AM
BuckLisa's Avatar
Well; I took advantage of the over $200+ off on a Rubicon RCV front axle shaft at Northridge 4x4 Black Friday special! Thanks gents for the advice! Moab part 2 next summer!
Old 11-27-2015, 09:46 AM
Invest2m4's Avatar
Dang, that is a nice deal. They are hard to find a discount on.
Old 11-27-2015, 11:21 AM
Sponsoring Vendor
Northridge4x4's Avatar
Thanks for the order!
Check it out
Search results for: 'rcv performance dana44 rubicon'
Quick Reply: RCV's or G2 Gold front shafts
