Rear e-locker decided to $hit the bed?
Quick background:
JKU, 37" MTRs, chromoly shafts, 5.13 gears & stock rear e-locker
The locker has been sticky for a bit but it would eventually disengage. Last month it stayed engaged for the whole weekend while I was wheeling so I took the rear cover off and manually pryed it open. Cleaned the diff out real good and engaged/disengaged the locker a few times and all was good. Went wheeling this past weekend and it won't disengage again. I manually pryed the locker into the open position through the fill hole but it's still engaged. Unplugged the wiring, disconnected the battery, rocked the jeep a few times (2 high, 4 high & 4 low), took the load off the rear wheels by jacking it up and beating on the diff with a BFH and nothing. The dash light is off but the thing is still engaged.
I am thinking it might be a bent shaft causing load issues on the carrier but I won't be able to pull my shafts until I get home in a week - currently working away from home.
Curious if anyone has any other ideas or experience. Has the locker finally shit the bed?
Thanks
Thanks
Odd that the dash light was off. If you're still running the stock electrical system the indicator should have either stayed illuminated or flashed. Of the two plugs going into the diff. One of them is the plunger that gives the system the status of the diff locker. Based on that signal the locker light is illuminated.
