Rear factory isolators?
AEV says to discard them. I discarded mine. If you want to secure your springs, you need to install coil retainers that bolt onto the bottom of your coils. Jks makes some.
I was wondering this recently since I was adding spacers to my rear. I searched and searched till I started looking up install directions. Daystar and teraflex both say to install the spacer with the factory isolator
Yea I think im going to eventually ditch the rear isolators. Since its ok not to use them I think it will look better without them. Thanks for the info fellas
1.75 Daystar coil spacers lift?????
When I installed the Daystar 1.75 lift last spring I did not put the rear isolator back in and have not had any problems.
Attachment 414146
Attachment 414146
