Rear sway bar links contract issue.
I installed some adjustable links on my rear swaybar today( installed jks lift last week) when I flex the top of the sway bar links is contacting with my tire...can i swap the links to the inside of the sway bar or are bumpstops my only option?
I run factory wheels with spidertrax
Do you have the stock wheels and tires? You may need more backspacing. A lift may also cause you to make tire contact. You can move the links to the inside of the sway bar and lower mounts for more clearance.
