removal of front drive shaft question-help please
How-Tos on this Topic Last edited by IB Advertising; 12-17-2015 at 04:14 PM.
See related guides and technical advice from our community experts:
Browse all: Four Wheel Drive Guides
Results 1 to 6 of 6
  1. #1
    JK Enthusiast JEP THNG's Avatar
    Join Date
    Aug 2007
    Location
    Indianapolis, In.
    Posts
    474
    Default removal of front drive shaft question-help please
    Ok, I am removing the front drive shaft. Without knowing any better I did step 4 before step 3 in WOL's write up.....
    4. Using a 15mm socket and a ratchet extension, remove the 4 bolts securing your Jeep JK Wrangler’s factory front drive shaft to the pinion flange as shown. If you cannot access the upper bolts, roll your Jeep forward or back a bit like you did in step #3 as this will help. With the 4 bolts removed, the axle end of your Jeep JK Wrangler’s front drive shaft will pretty much fall off however, the transfer case end is seated inside a flange and may take a little effort to get it free. If needed, tap the sides of the drive shaft with a dead blow hammer as that will help.
    3. Using an 8mm socket, remove the 8 bolts securing your Jeep JK Wrangler’s factory front drive shaft to the output shaft flange on the transfer case. Accessing these bolts can be very difficult and you may find that you can only remove a couple at a time. As you remove the bolts you can, stop what you’re doing, put your transmission in neutral, release the parking brake and then roll your Jeep just a bit forward or back until you can access more of the bolts. Put your transmission back in park, re-engage your parking brake and then continue removing more bolts.
    My question is how do I get the driveshaft to stop spinning so I can get the drive shaft off of the transfer case output flange?????
    I know this is a dumb question, but I am at a loss...do I have to reattach one of the bolts to the pinion flange?
    Thanks in advance.
  2. #2
    JK Enthusiast MikeRM's Avatar
    Join Date
    Mar 2011
    Location
    Clarkston, MI
    Posts
    151
    Put the transfer case in 4HI
    2010 Rubicon 2-door
    Teraflex 2.5 Spring Kit w/Bilstein 5100 Shocks
    Warn M8000
    Ace rock sliders
    17 x 8 Cragar D-window, 305-70-17 Goodyear MTR/K
  3. #3
    JK-Forum Founder
    Join Date
    Jul 2006
    Location
    Laguna Niguel, CA
    Posts
    36,537
    Quote Originally Posted by MikeRM View Post
    what he said, shift your t-case into 4wd
  4. #4
    Join Date
    Aug 2007
    Location
    Indianapolis, In.
    Posts
    474
    Thanks guys!!
  5. #5
    JK-Forum Editor
    Join Date
    Jan 2016
    Posts
    75
    Default How-To Tuesday
    Perfect topic for today's How-To Tuesday...
    http://www.jk-forum.com/how-tos/a/je...eshafts-407884
  6. #6
    Super Moderator Canvas's Avatar
    Join Date
    Mar 2013
    Location
    Denton County, TX
    Posts
    878
    I used a impact wrench and held the driveshaft, but putting the transfer case in 4HI works too.
    NORTHRIDGE4X4
    The Price of Freedom is Written on the WALL.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
