Rock Krawler Suspension Open Tech Line for JK Forum Members
#362
Former Vendor
Hi Rock Krawler. So I got a slight issue with my front TB. I have a loud popping sound when turning. I'm pretty sure that's where the popping is coming from. I've greased everything, and the issue is still there. It feels like there is some slight play also. Everything seem to be tight. Any help would be great
Other items to check:
Sway bar links
Tie Rod Ends
Steering Box
Ball Joints
#363
Former Vendor
RK
#364
Krawler joints.
So I put an x-factor lift on the jeep back in 2011. I decided to go thru everything and the Krawler joints are seized up. Anyway I'm going to put new Krawler joints as I had my buddy machine them out.
So anyone have part numbers for the rear upper and lower control arms. Threads are 1" and the smaller shank is 7/8" 14 threads per inch.
Also need to replace the poly bushings with something.
I see the new joints are available with grease zerks?
It's the mid arm kit
#365
As you can see in this picture, mine was exactly as I explained, and it was not bent.
#367
As soon as we decide to lift our Jeep, we start mucking with the steering geometry and center of gravity, etc. That's the biggest issue that most new Jeep owners (including myself) don't always know could be a problem. There are ways to address these issues, however, so all is not lost.
So, if you are asking what "needs" to be added to a Flex in order to make it "complete", I would add, at a minimum, rear upper adjustable control arms and bump stops. Not sure if that answers your question or not.
If I could do it all over again, I'd still get the X-Factor, but I think I would have spent the time to have the rear spring perches relocated rather than using the spring wedges I have now, and probably looked into replacing the front axle with a caster corrected housing. I still may do that someday.
#368
Not sure I understand your question. If you haven't already, read TheDirtMan's sticky on lifts. There are so many variables, as to what constitutes a completed lift. For me, the Flex was not complete enough. I went with the X-Factor. And it's still not complete enough. For you, that may be a different answer.
#369
Shocks/stops is it unless you buy a stage 1/2 kit.
I know NR and other venders package shocks and bumpstops in with RK kits.
#370
