Rockkrawler benefits of MAX over FLEX?
#21
you are correct and rock krawler told me that using just the 1.5" coils ala carte is perfect way for non hard core people to go. I run just coils with 7000 rancho shocks and extended sway bar links front and rear and 2" bump stops with 34" tires and it does anything I will do. I wheel a lot with Willie Worthie and he is impressed with the set up. That is good enough for me lol.
Sorry for the derail..
#22
he will appreciate it. He is a good friend and great guy to wheel with.
#23
IMO the max travel is kinda a waste. The rear lower arms are shorter to barely longer then stock. Their only purpose is clearance and maybe a little less bind. Upgrading to the X Factor (all 8 arms), the rear lowers are replaced w/ longer lowers. Paired with the longer uppers move the axle back 1-1.5" Fwiw, using the short lowers for pinion would pull your tire in toward the pitch seem (adjusted shorter then stock) If somebody wants/needs pinion correction. RK will shorten a set of uppers for you. You can still run those with the short lowers... they would be maxed out centering the tire in the wheel well. 2007 Rubicon /2 door/6 speed
Thanks!
