Roller Fairlead with Synthetic Rope?
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    May 2008
    Location
    Los Angeles, California, United States, United States
    Posts
    8
    Default Roller Fairlead with Synthetic Rope?
    Any thoughts out there on using a roller fairlead with synthetic rope? I have seen it done, but I understand the potential problem with pinching the rope in between the rollers. I want to keep the rollers to mount my license plate since there is nowhere else to put it.
  2. #2
    Join Date
    Oct 2006
    Location
    Denmark
    Posts
    31
    You can use a roller fairlead with synthetic rope, but be careful that the rollers a close together.
    There may be a problem if your pulls are often through the "corners" as the rope gets kind of squared, but when strain is off the rope will re-find its former shape.
    With the non roller fairleads you can still mount your license plate.
    Fit a hinge and lock plate with magnets or you can use a plastic clip, as on the rollers, just squeezed inside the oblong hole instead of outside on the rollers.
    There was a company that offered that "clip", but I can not find the link anymore.
  3. #3
    JK Freak JulianK's Avatar
    Join Date
    Jan 2007
    Location
    Gatineau (Ottawa area), Canada
    Posts
    807
    I'm pretty sure I saw a fairlead for rope in one of the catalorues.
  4. #4
    JK Super Freak NE Wrangling's Avatar
    Join Date
    Nov 2007
    Location
    Massachusett
    Posts
    1,258
    Typical rollers will catch the rope if it's not a straight on pull. Remember under load the rope will compress a little. Better off finding another solution for the license plate since if you need to use the winch it's a undeeded risk.
  5. #5
    Join Date
    Jan 2007
    Location
    Posts
    807
    http://www.winchline.com/fairleads.htm
    Last edited by Robar; 10-16-2008 at 10:34 AM. Reason: PLEASE DO NOT POST DIRECT NON SPONSOR LINKS
  6. #6
    Former Member tgrt's Avatar
    Join Date
    Apr 2007
    Location
    Carrollton, Georgia
    Posts
    3,619
    Go with a hawse fairlead. A roller fairlead might work, but it may also ruin your expensive rope. You can turn around and sell your roller fairlead for as much or more as the hawse fairlead.
    Anthony - 2007 Rubicon
    Die-Tech Off-road
    American steel. American made.
    mirror relocationĚevap. relocationĚc-gussets
    www.dietechoffroad.com - Follow us on Twitter!
  7. #7
    JK Enthusiast silver rubicon's Avatar
    Join Date
    Dec 2007
    Location
    Fontana, ca
    Posts
    198
    if you insist on using a roller fairlead, make sure it is new or in like new condition; any nicks or gouges can act like razors on your rope.
    '08 Unlimited Rubicon
    TeraFlex HD budget boost
    ProComp 8128 (17X9)
    315/70R17 Mickey Thompson MTZ
    LoD winch bumper
    LoD Signature Series rear bumper/tire carrier
    Warn 9.5ti.
    Piaa lights
    NORTHRIDGE4X4
  8. #8
    JK Super Freak Strong Bad's Avatar
    Join Date
    Nov 2007
    Location
    Hinton, OK
    Posts
    1,041
    Quote Originally Posted by silver rubicon View Post
    Ditto!! It won't take much of a burr on a roller to jack up your rope.
    2007 2 Door Rubicon (6 Speed), Atlas II T-Case, Front & Rear Dynatrac ProRock Dana 60s, 4" FT Long Arm, 5.13 Gears, 37" Pro Comp Mud Xtremes on Spyderlock Beadlocks
  9. #9
    Join Date
    May 2008
    Location
    Grand Junction, CO
    Posts
    1,279
    I spoke to Thor at Winchline and he feels the supposed requirement for a hawse fairlead was a myth. When I bought my synthetic line from him I was willing to drop the dollars for a Hawse and he talked me out of it. Bill Burke of Bill Burke 4 Wheeling America has been running sythetic since it first became available and has roller fairleads on both his rigs.
    The only caveat with a roller fairlead is not to use one that has been cut by extensive wire use.
    As I recall Thor at Winchline said that a roller fairlead was much easier on the rope.
    08 Rubi 4dr, GM 6.2 LS with GM 6L80 6 speed auto, Dynatrac ProRock80 in rear and in front PR60 w RCV shafts, Big Brake kit, DynaLock with Stub Hub, 4.88 gears and ARB lockers, 4" lift, King coil-overs, PSC steering, 37" MTR's, Hutchison Rock Monster dual beadlock wheels, RockHard Front Bumper, Rocker Guards, Rear Bumper w custom Tire Carrier, custom TC skid, Warn PowerPlant w syn rope, Tuffy Drawer, 60" Hi-Lift, PullPal, Cibie headlights, ARB fridge.
  10. #10
    JK-Forum Founder
    Join Date
    Jul 2006
    Location
    Laguna Niguel, CA
    Posts
    36,537
    you'll forgive me but the whole roller fairlead thing and them pinching the rope is nothing more than an old wives tale. at least, i have never seen it happen, i have never seen it coming close to happening and yes, i am speaking from experience. i have been using my viking winchline for years on a roller fairlead and extensively and even on EXTREME side pulls for hours on end. in fact, thanks to the fact that rollers extend as far out as it does, they actually make extreme side pulls more possible to do than with a hawse which is practially mounted flush on your bumper. the ONLY thing you need to make sure of is that IF you use the existing steel rollers, they have not been used with wire rope in the past. as mentioned, any damage, abrassions or flaws in it will damage your synth line. if this is the case, you can buy a set of replacement thermoplastic rollers like these:
    http://www.northridge4x4.com/proddet...=VIKING-ROLLER
    this is what i use and without any problems.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
