Rough Country Lift Comparison Opinions?
Hi guys,
I have a 2013 wrangler unlimited and I am looking for a good lift. Currently I am between the Rough Country 4" x-series suspension lift (4in X-series Suspension Lift Kit for 07-14 Jeep JK Wrangler Unlimited [674X] | Rough Country Suspension Systems)
and the 3.5" suspension lift (3.5in Suspension Lift Kit for 07-14 Jeep JK Wrangler Unlimited [609S] | Rough Country Suspension Systems).
not sure if the more expensive one is necessary my goal is to clear 35's with no rubbing. Thoughts on these lifts? Would you recommend a different one?
I know there are a lot of threads similar, I searched for similar info on the Rough Country lifts and didn't find anything, sorry if I missed something!
Thanks!
Thanks!
Start with the two threads stickied to the top of this modified area. That should give you some background on lifting, a better idea of the issues you are likely to run in to when you lift, and the components you will probably want to fix those issues.
Are you willing to run flat flares, or trim your stock flares? You will be much better off going with a smaller lift and flat flares, than a taller lift and stock flares.
There are quite a few threads for the RC lifts, do a couple more searches and you'll find tons of feedback. (The majority of which will tell you not to cheap out on a lift...)
You don't need a 4" lift to clear 35's. IMO I wouldn't buy any rough country lifts unless it was my last choice. But that's just me, other people run RC lifts and don't mind them. I would go with a smaller lift that's better quality and flat fenders like he said.
I have the 3.5" series ii lift on a 2 door. I know most here will bash RC, but I have had no issues at all with my kit and imo it rides very comparable to a stock JK. Install was pretty smooth. Took me and a buddy about 6 hours to put it all on. I think the new shocks are much better than what previous kits came with, or so I hear. I've had this lift on for about a year and a half and about 20k milea or so. It's holding up fine and like I said, I have no complaints. I think it's a pretty great kit for the money. Also my Jeep is on 35" km2's and I have plenty of room.
Thank you, I really appreciate the input!
Have you had any wear issues not having all 8 arms? That's my big wonder between the kits.
I had posted this before on another thread-
I bought the 4" X-flex system (4in X-series Suspension Lift Kit for 07-13 Jeep JK Wrangler [673X] | Rough Country Suspension Systems) because for the money you can't beat it... you get everything. The control arms are VERY beefy and I was impressed with the ride quality and flex. Now my only complaint are the RC Flex joint (fake johnny joints). I had the first one rip apart within 15 miles of driving to the trail (on flat pavement). With in a week ALL 4 front had ripped apart and I had to put spot welds on the screw-in side washer to keep them together. I heard RC support is great and I could have called them for replacement but I didn't waste my time, I just ordered real Johnny Joint replacement ends (all 8 for front and rear) and now everything is ROCK Solid and still way under what I would have paid for everything from another kit. And yes, I wheel the crap out of it
Rough country is the lowest quality aftermarket Jeep suspension made.
At 80 mph I'd rather not have a critical suspension component just fall apart .
This...
Then...
This...
I have the 4.5 on for 2 years springs and shocks are as good as new. I did add the arms and one of the joints on the front came apart. It was a install issue not RCa fault. Replacement was a piece of cake. Their support is great!!
Oh by the way it's 4.5" and 33's.
