Rubicon Rear Axle Shaft Replacments
Ten Factory JK 32 Spline, Rubicon, Dana 44 Rear Chromoly Axle Kit - TENMG22157-PRESSBEARING
Ten Factory JK Non-Rubicon, 30 Spline, Dana 44 Rear Chromoly Axle Kit - TENMG22156-PRESSBEARING
These are the pressed bearings prices.
this is the backing plate
Crown Automotive Rear Axle Shaft Seal Retainer - 68008523AA
If G2 is a consideration, it's worth a call/email to try and get confirmation...
Here is the thread:
https://www.jk-forum.com/forums/modi...-axles-325733/
Been doing some warranty research.
G2 warrants them for 10 years. The gold version is 25 years.
Ten Factory carry a 10 year warranty (or 100,000 miles).
Alloy USA is also a 10 year warranty.
Nitro Gear is only 5 years.
I'm heavily leaning toward Ten Factory.
Am on 38's and RVCs front and rear with no issues to date. Buy once cry once in my opinion.
Sponsoring Manufacturer
I picked up a Rubicon take off with the Rubicon locker in it (32 spline) and I will be replacing the shafts.
I will probably try to find something with the bearings pressed on already and will also replace the seals and the retainer. I assume the ABS tone ring as well.
I've seen the Nitro Gear Complete on NR4x4's site, but I'm not sure what else might be out there.
I would appreciate any experience you have had, good or bad, and some recommendations.
Dynatrac? Introduces JK44 Pro Axleshaft Kits | Dynatrac Tech Info and News
If you've got any other questions, give our tech line a call at 714-421-4314 and we'll get you helped out.
For my black "built" rig "Brett" I bought RCV shafts for the rear from David's team at Northridge. They'd already done my ProRock 44 up front and I'd gone with RCV for that, so I kept RCV for the rears too. No issues to date. Love RCV.
Yeah, I'm sure they're great. But at $1800 a set, I have to pass. That's just way more than I can put into this right now.
