Something weird going on after lift install
Results 1 to 7 of 7
  1. #1
    Join Date
    Jun 2012
    Location
    MASS
    Posts
    18
    Default Something weird going on after lift install
    I just installed a 3 inch teraflex lift and I took it out for a ride after getting it all together. I installed the extended brake lines and when driving it it feels as those at random times pressure is being applied to the brakes. What do you guys think this is? I bled the lines do you think there could still be air in them causing this problem?
  2. #2
    JK Super Freak ronin2120's Avatar
    Join Date
    Sep 2011
    Location
    Fort Lewis, WA
    Posts
    1,037
    If you had air in the line still your pedal would be soft and go to the floor. When you did the install did you over extend any of the lines or during reinstall did you pinch one of the lines? I would recheck those and see if you have anything obvious.
    3in Teraflex with full flex arms and Fox Shocks
    17in AEV Pintler Beadlocks
    35in Nitto Trail Grapplers
    Front PSC Brawler Lite
    Rear LOD Gen III
    PSC Aluminum Fenders
    PSC Rocker Knockers
    Offroad Evolution Protek Skids
    Coast front/rear drive shafts
    RCV's / sleeve & gusset front axle
    Warn 9.5 Scti
    Banks Monster Exhaust and Intake
    Rigid Dually D2's
    10" SR Light Bar
    NORTHRIDGE 4X4
  3. #3
    Join Date
    Apr 2012
    Location
    St Louis
    Posts
    254
    Check to make sure those hoses aren't twisted. I've seen people install calipers and have the line twisted when bolting the caliper back up. It could restricts the flow. Just double check
  4. #4
    JK Freak KCTW's Avatar
    Join Date
    Sep 2007
    Location
    Lanark IL
    Posts
    741
    Your steering wheel isn't off center, and the ESP is applying the brakes is it? Do you feel it going around corners?
    2008 Jeep Wrangler Unlimited
    4" EVO/JKS lift - 35" Kumho Road Venture MT - Method wheels - Bushwacker Flat Flares - Superchips Flashpaq - PSC Brawler Lite front bumper - Warn M8000 winch - PSC DIY Rico steps - custom rear bumper
  5. #5
    JK Super Freak Freewill's Avatar
    Join Date
    Jun 2011
    Location
    Olympia, WA
    Posts
    1,711
    Did you re-center the steering wheel? Is there a lightning bolt icon blinking in the dashboard when you feel the brakes come on?
    '11 JK Sport hardtop auto, 4.56, air lockers
    2.5" spring lift, 32 MT rubber
    Bumper & winch & some other stuff
  6. #6
    Join Date
    Jun 2012
    Location
    MASS
    Posts
    18
    Steering wheel is off center. I don't see the light flashing but I will check and I it doesn't really matter if it's on a corner or straight
    09 Flame red Rubicon
    3 inch Teraflex
    35" Toyo Open Country M/T
    20" XD Addicts
    DIY marker lights into turn signals.
  7. #7
    Join Date
    Jun 2011
    Location
    Olympia, WA
    Posts
    1,711
    This may save you some time:
    To center the wheel, change the length of the relay rod (some call it a drag link). Its runs across the Jeep parallel to the tie rod and has an adjusting clamp about 3" long with two bolts.
    The tie rod has a knurled plastic adjusting collar. If you mess with the tie rod accidentally you'll need to set the toe-in also.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
