Stability control
Stability control
Hi all.
My stability control light is now on all the time.
What has happened is that I replaced my broken nexsteer steering box with a Delphi box. At the same time I added some front lower control arms.
The shop that installed it has said that the wheel is dead centre and that the light is on because the new box is a jku box which is different gearing to my jk?
Has anyone come across this issue before? I'm scanned for codes (none) with my superchips tuner but I was going to get the stealership to scan it anyway?
Should I try adjusting the trackbar or not?
Thanks all
Thanks all
So it appears I was incorrect about the steering boxes...the 2dr and 4dr are different.
I understand the 2dr has a slower ratio due to the shorter wheelbase and the 4dr has a faster ratio due to longer wheelbase.
Using a 2dr box in a 4dr should not cause issue but using a 4dr box in a 2dr could cause issue.
So two things come to mind....double check your steering wheel for center and check for damage to the clock spring. If the steering wheel wasn't tied off during the steering box replacement and the wheel moved it could have damaged the clock spring.
So went to the stealer ans they plugged in the laptop. Turns out the wheel is out 361 degrees. Cant believe the clock spring isn't broken.
Hopefully the light goes off when I fix this
