Stock bumper winch plate
Making one is pretty easy as well.
I got a winch plate from Harbor Freight and mounted upside down
It works perfect
AMen
It works perfect
AMen
There are times when function over form is the right way to go. Stealth mounting a winch might look cool, but it is far from "cool." If you actually use a winch, it needs a lot of air flow. Stuffed in a bumper is the last place you want it. Performance will suffer and you will run into overheating issues. Manufacturers don't warranty a winch that was burnt out after overheating. Not to mention there is no access to the spool motor for service. Every couple of uses I like to re-wrap the line. I can't count how many times I've seen a winch fail on the trail and it was due to a lead to the motor coming a little loose. To summarize, if you plan to actually use your winch, then it doesn't belong in your bumper.
I did this to my bumper a while back. Used a smittlybilt x20 10k winch and Olympic 4x4 recessed winch plate (for their Boa bumper). Just had to cut some holes in the bumper to make it fit. I wrote a install thread about it on Wrangler Forum. (Recessed winch project).
Wow that looks good. Nice job!
that's so badass!!! Great job! I don't think I'm a member on wrangler forum. I'm going to search it now
haha. I was banned on Cherokee forum for like a week for absolutely nothing. I know there isn't freedom of speech on forums I'm not sure about freedom of press. Try to pm it to me?
