Superwinch Epi9.0 mounted on Factory Bumper
I just ordered the 9500ti and will soon be doing this mod, thanks again.
(4wd has a great sale on them now)
Oh and were you able to pick up the winch plate at Harbor ? or did you have to order online? (NEVERMIND this, I see your original post mentions shipping costs)
Any reason you went with the Superwinch?
I found a Warn 8000lbs winch for about $75 cheaper.
Just looking for opinions because the vendor was pushing me towards the Warn over the SuperW
The SuperWinch is rated 1000lb more than the Warn, I like the looks of the SuperWinch better, and I've seen both used on the trail. The SuperWinches I've seen were as fast if not faster than the Warn 8000 unloaded and loaded, and the Superwinch pulls less of a load on the battery. Don't get me wrong, the Warn 8000 is a great winch. If you wanted to save some $$$ it would be fine. But then again, if I was going to save $$$ I would probably buy one of the Smittybilt 8000lb winches for $299 from 4wd.com.
is it possible to do this by mounting it to the bottom of the frame rails? that would drop the winch down lower like the bumpers being released for the jk with the resecessed winch mounting... not sure if that would put it too low to line up with the front of the bumper was just thinking? or is this not possible?
i love the way that looks at least its recessed a bit the way you have it. just wondering if its possible to have the bulk of the winch in the bumper without having to install it upside down like the other mod i've seen here.
I also agree about the Smittybilt but after talking with 4wd, they're on backorder until late Sept at the earliest.
Thanks again
