Sponsored by:
Sponsored by:
Suspension and ride quality - not another lift thread
Old 05-18-2016, 08:02 AM
  #21
Former Vendor
Rock Krawler Suspension's Avatar
Originally Posted by BLK08JK
So far I've found AEV and Synergy as having triple rate... Any others out there you guys are aware of?
Our RK coils are triple rate and tuned around what you are looking to achieve. There are many ways to tune coil springs with multiple rates. The AEV coils are tuned more around load capacity and Expedition style rigs. Synergy says theirs are progressive so that could mean many things or even straight progressive which is a constantly increasing rate.
RK
Old 05-18-2016, 08:41 AM
  #22
Jonathan_JK's Avatar
Yes RK knows what he's talking about. Perfect examples. I wish I could afford the King or Fox Triple bypass shocks. I would have to sell a kidney for what they want for them. You can make a Jeep go fast but it will never be in the same league as a Ford SVT Raptor we just aren't built for that.
Old 05-18-2016, 08:51 AM
  #23
Former Vendor
Our coils are Triple Rate as well with a design intent to what you are looking for! AEV Triple rate are designed for more load carrying purposes for Expedition style rigs. Synergy states there coils are progressive which could have many variations to the definition.
Coils spring tunes or specs are unique to each manufacturer's design intent. Just remember that when selecting coils.
RK
Old 05-18-2016, 01:48 PM
  #24
kjeeper10's Avatar
Originally Posted by TheDirtman
Yes they were the older coils. A true dual rate coil would have two different sections that are rated for different loads and both should be available in normal use. It just has to do with the number of windings and the thickness of the coil steel. A fully compressed section at ride height that allows for extra droop is a tender coil, not really a dual rate. What RK calls a triple rate is actually a dual rate (usable) with a tender on top.
Then MC's coil would be linear, not dual like described. I mean it acts like a linear coil installed on the jeep.
Old 05-18-2016, 06:13 PM
  #25
DunnyBunny's Avatar
I would disagree with the raptor part. Having a truck that is IFS and competes with raptor with a simple suspension upgrade, the raptor isn't all that great. It's got some King shocks. Whoopy.
Take a look at the right builds and watch some videos of jeeps going fast and you'll see that the Wrangler can easily outperform the Raptor. It's all about the suspension setup and power to push it.
Old 05-18-2016, 07:40 PM
  #26
BLK08JK's Avatar
Originally Posted by Rock Krawler Suspension
That is exactly how our Triple Rate Springs work and are tuned. If you paired them with some good shocks, air down, you will be on the start to something that will work for what you are looking for...
RK
So which is it really? Are there "usable" triple rate springs - using all three rates? On RK's website, looking at component upgrades is the only place I see triple rated springs mentioned, all the kits refer to them as multi-rate.
I've been trying to find the right builds and videos, the only vids are Teraflex Prerunner stuff. If you know of others please post them up. I mean the RK max travel kit looks similar to the TF Prerunner kit minus some bracket stuff. Both of them get into long arms, caster and pinion adjustments where I'm too much of a noob to do this myself.
RK's website is difficult to determine the purpose and difference between kits.
2.5 Stock Mod System, overland, max travel, flex system, x-factor - all Multi Rate Coil Springs,
overland vs flex for example? Overland has some rear links and front brakelines? Flex doesn't?
Originally I wasn't even thinking of lift, I'm not trying to run bigger tires as my 3.8/trans combo is anemic now with 32's. But there are zero multi or triple rate coils without increasing height. Shocks and bumpstops - easy peasy. Coils, not so much. Still a bit confused - Dirtman saying RK not truely triple rate, RK saying AEV is more overland tuned, RK website using muti-rate/triple rate interchangeably and I don't fully see the benefits of having 5 different 2.5" kits - one adjusts only caster, the other pinion and caster, makes it confusing to know what is actually required to make it ride well.
Old 05-19-2016, 01:14 AM
  #27
Yamaha90's Avatar
I love our RK 3.5 Triple rate coils, they ride noticeably better than their previous version.
OP, If you're not looking for very much lift RK has a 1.5" coil that would yield a better rate than your current coil, with minimal lift. When paired with a better shock absorber, you can achieve a much better ride for the trails you're traveling.
Old 05-19-2016, 01:56 AM
  #28
kjeeper10's Avatar
I really dont know whats what when talking about coil springs. RK calls theirs triple rate (Ride, Firmer, dead zone). MC calls theirs dual rate (Ride, dead zone)
On road with RK's only 2 rates are used, MC on road a single rate. So if one is going to call RK's a dual rate MC's would be linear.
The question is, is the dead zone or tender like
dirt said considered a rate even though its not used or inactive.
Old 05-19-2016, 06:11 AM
  #29
TheDirtman's Avatar
When you are looking at these coils that use a dead zone on top (tender) They are made for long travel and have nothing to do with ride quality. If you don't run a long travel shock the "dead zone" type coils are not a benefit.
Just to be clear, you are going to need other stuff like tuned shocks and air bumps to drive like a pre runner with plenty of up travel.
Old 05-19-2016, 06:30 AM
  #30
Former Vendor
When you are looking at these coils that use a dead zone on top (tender) They are made for long travel and have nothing to do with ride quality. If you don't run a long travel shock the "dead zone" type coils are of on benefit.
Just to be clear you are going to need other stuff like tuned shocks and air bumps to drive like a pre runner with plenty of up travel.
Great stuff right here.
To also add to Dairyman's comment on long travel with dead zone coils, that is not long travel like long travel IFS. The dead zone only comes into play with a lot of droop in the suspension system as all the standard travel in the coil is unloaded.
To "go fast" you will need a good amount of well controlled up travel. Low COG setups are not the ticket for going fast....
Hope that helps. There is a lot of good information in this thread...
RK
Quick Reply: Suspension and ride quality - not another lift thread
