Sponsored by:
Sponsored by:
Teraflex HD tire carrier installed
Old 12-11-2013, 05:05 PM
troyoffroad's Avatar
Default Teraflex HD tire carrier installed
I just installed my new Teraflex HD tire carrier last night in preparation for the 37's coming soon. If anyone is considering one of these, I would highly recommend it. Once installed, this thing is solid. I was able to sit on the tire with tail gate open(I'm 6' and 195lbs.)!
Old 12-11-2013, 05:11 PM
Twash53's Avatar
One of the best mods I did on my jeep.... Very solid piece.... I was running my 35 on the stock carrier and it was bouncing around everywhere.... Much better with the hinged carrier and pretty easy install compared to other carriers....
Old 12-11-2013, 05:20 PM
^agreed^...…
Old 12-12-2013, 11:13 AM
jstikel3's Avatar
Cant wait for my 33s to wear out that way I "need" to get one of these to handle a 35.
Old 12-12-2013, 11:57 AM
AUJeep's Avatar
Will I need the hinge and the mount for a 35" Toyo Open Country(~85lbs with the wheel)? Or can I just get the teraflex hinge and use the stock mount?
Looks good by the way.
Old 12-12-2013, 12:06 PM
blue project's Avatar
Attachment 516293
Just noticed your also from Cape Cod!
Old 12-12-2013, 12:08 PM
LoneWolf's Avatar
I'm pretty sure TF recommends you use the mount, too, if you're going with 35s or larger.
Old 12-12-2013, 02:39 PM
Wightmn's Avatar
Just installed mine as well. It's very solid. I wouldn't run the stock carrier. It appears to be made of pot metal and weighs almost nothing. It will also keep a wheel with low back space from even contacting the factory snubbers. The Terraflex carrier allows you to pull the wheel in tight to the gate. Nothing to rattle.
Old 12-12-2013, 03:03 PM
nthinuf's Avatar
You can use the stock carrier.
No issues running a 35 with the TF Hinge and stock carrier, and I have even had a 37 on it for two months now. (Not sure if the TF carriers were backordered, but it took about 6 weeks to get here. It'll be nice to get the 37 moved up some.)
Old 04-14-2014, 06:04 PM
I am. What town are you from? I'm about to start my new 2014 build up. I have all the parts ready to go in my garage!
Quick Reply: Teraflex HD tire carrier installed
