Tires... just need to vent...
#21
Not really, although it's not in the plans of most people. Hugely better off-road experience, significantly better high-way experience (if you do it right), and you'll never have another balance induced steering shake no matter how screwed up your tires are (my tires are extremely screwed up and cannot be balanced and were undriveable on stock steering due to steering oscillations and shakes. Now completely smooth). And if you can weld and tap your own gear box it's very cheap, right around 10% the cost of PSC.
I can't believe more people don't do it, people treat it as something you do if you're hard core wheeling on 40's. It's the best upgrade I ever did on 35's and I'd say the same thing even if I never left pavement.
Assuming you're a more sane person than I am, ignore me and go get your tires road-force balanced at some other shop! Balancing tires isn't easy and some shops just don't have technicians that know how to do it.
#23
It's important to note 200 miles ago when I had the stock tires on there, it rode absolutely perfect to 85mph. (Never been faster than that)
#24
I'll take a look at it. I don't really have any steering wheel wobble to speak of. The whole vehicle is bumbling around. I aired down to 30 from 37 or so and it's better, but it's still happening.
One other thought, are the rims new? Some after-market rims you have to remove the clips that hold the brake discs on (the clips are not necessary). The clip will sit between the hub and the wheel putting it at an angle and it'll do awful things to your ride quality.
#25
Stock wheels/rims. Same ones that were fine a few weeks ago.
Just swapped front/rear tires. Will go for a test run in the morning and see if things move into the steering wheel. Right now the whole tub is hopping up and down.
