Too much Toe-in
Originally Posted by mkjeep
Hmph,with those specs your total toe would be .40, almost 1/2in. Your tires are gonna chew up in the front, I know this from experience.
Originally Posted by EzK
Degrees are not = to inches.
Originally Posted by RubiconRod
So do I have too much toe-in?
Truel. I was thinking of front ends in general. Far as I know you are shopping for a new axle housing if the JK camber is out, although replacing the "C" bracket might work in some cases.
Originally Posted by orfanidisnikolaos
As far as i know you cannot adjust camber in a jk, cause it has solid axles.
Yes. Just have them set it within factory specs. A good alinement guy will know how to set your toe.
