Sponsored by:
Sponsored by:
Torque for Rock krawler jam nuts
Old 09-04-2013, 01:41 PM
j3r3myjam3s13's Avatar
Default Torque for Rock krawler jam nuts
What setup did you use to torque your jam nuts to 220lbs on your Rock krawler arms???
Old 09-04-2013, 01:49 PM
Monte417's Avatar
I just used a big adjustable wrench on my RC arms. There is no way of measuring specific torque with this method but I had a good idea. 50k miles no problems
Old 09-04-2013, 01:52 PM
ronin2120's Avatar
We used the "Jesus" wrench to torgue the nuts down then just checked them every 250 miles for the first 1,000 miles. After that just check them after wheeling or during an oil change.
Old 09-04-2013, 03:11 PM
Former Vendor
Smashboogie 4x4's Avatar
Lock the arm in a vice, put loctite on the threads, get a big wrench and put all your weight into it. Even if you put 300lbs of torque on them you won't damage anything.
Old 09-04-2013, 03:56 PM
MMXJKU's Avatar
Once the jam nut is jammed good and tight put a drop of paint on the nut and the arm. This will give you a visual reference to see if the jam nut is coming un-jammed.
Old 09-04-2013, 04:11 PM
So what im hearing is........nobody has a good way to properly toque them. I bought a 3/4" torque wrench and plan on using a 1-1/2" crowsfoot to get it done. Was hoping someone had tried something similar to this already
SoK66 (12-27-2023)
Old 09-04-2013, 04:31 PM
scooby snacks's Avatar
Man-handled mine!! Did buy a crows foot for my torque wrench but it was a pain so I went 'Rambo' on mine...
Old 09-04-2013, 04:33 PM
AaronJK's Avatar
You don't have too, just make them as tight as you can while keeping the joints aligned. You can't over tighten them. If you can RK will give you new ones, they said so in their tech thread.
Sent using my SuperSmartThinky Phone
Old 09-04-2013, 04:53 PM
Hot94Z28's Avatar
What size is the nut? I was thinking of buying a wrench and cutting down to fit in the tight spots to help tighten them. I am paranoid since I just installed it getting it all tight.
Old 09-04-2013, 05:08 PM
The arms take a 1-1/2" wrench ( but it fits loosely), the others are 1-5/16" wrench and it fits loosely to, i tried some metric sizes but none fit any better, kinda sucks considering the amount of torque they specify.....
Quick Reply: Torque for Rock krawler jam nuts
