Sponsored by:
Sponsored by:
AEV Coil Spacer Question?
Old 12-02-2012, 06:59 PM
Andre's Avatar
Default AEV Coil Spacer Question?
Hi Folks,
I've tried searching and can't find quite what I am looking for... Hoping someone wiser than I can provide some guidance!
Current set-up is an 09 Rubi 2dr with a Rough Country 2.5" coil lift & shocks. Due to bigger tires & new rear bumper the rear is now sagging about 1.25" lower than the front.
I have a 2" AEV BB kit sitting in my shop... Is there any reason I can't (or shouldn't) just install the rear portion of this kit to level the Jeep out? I realize the rear would now sit higher than the front but I'm OK with that.
Any (constructive) input is greatly appreciated!!
Thanks in advance,
André
Old 12-03-2012, 06:07 AM
Andre's Avatar
Bump... Does anyone know if this is feasible or not?
Thanks!!
André
Old 12-03-2012, 06:23 AM
darkhelmet's Avatar
Originally Posted by Andre
Hi Folks,
Thanks in advance,
André
I currently have the AEV spacer lift on my jeep. All it does is sit on top of the spring; and since you are just using it to regain some height that you lost from weight, I don't see any way it would hurt anything.
Old 12-03-2012, 06:32 AM
Delux2769's Avatar
That would work perfect for you.
You will be set back to a good height.
Old 12-03-2012, 07:01 AM
Andre's Avatar
Thank you both - just wanted to make sure there wasn't something I was missing or unaware of.
Cheers,
André
Old 12-03-2012, 12:22 PM
Freewill's Avatar
Spacers work when a spring is supporting the weight OK, but more height is needed. I'd never use a spacer to compensate for a spring that has sagged. Replace the springs. Its the same amount of work and not much more money.
Old 12-04-2012, 08:32 AM
Ncb
Ncb's Avatar
I would install a 1" Teraflex spacer. I think it's a better design.
Quick Reply: AEV Coil Spacer Question?
