Sponsored by:
Sponsored by:
Trail Gear Ram Assist
Old 01-20-2015, 02:14 PM
SF Nick's Avatar
Default Trail Gear Ram Assist
I was looking at Ram assist & came across this
Has anyone installed this on a JK? Is a 1.5"X 6" the correct size? The PSC is too expensive & I'm too lazy to call Redneck Ram. Lol
Old 01-20-2015, 04:16 PM
JE8154's Avatar
I ran a psc 1.5"x6" ram stroke is about 5.5" had enough travel for me. Measure your steering throw and you'll be able to tell how long of a ram you need. Killed my stock pump, upgraded to the psc pump and had to go to a 1.75"x6" ram.
Old 01-20-2015, 04:30 PM
SF Nick's Avatar
Thanks for the reply. I measured my Throw & it seems like the 6 will work for me too. So if I plan on getting the PSC pump & reservoir I should get the 1.75?
Old 01-20-2015, 05:03 PM
JE8154's Avatar
Unless you like buying stuff twice, I'd say get the 1.75
Old 01-20-2015, 07:48 PM
Maertz's Avatar
Im rocking a 1.5 x 8 inch on mine with stock pump. No problems so far. Normally the smaller the ram the faster the response but less power. If your getting a psc pump sure 1.75 will work but nothing wrong with a 1.5. many people have been running a 1.5 on 40s plus on stock pump for years. If you do not bleed it all properly id say your severely increasing the odds youll fry your stock pump.
Old 01-21-2015, 05:28 AM
JK Forum Regional Rep
familytime's Avatar
Go with the larger bore and hi volume pump/reservoir from PSC.You find the smaller bore is very sensitive and you should be ok with the stock pump unlike the larger bore requires more volume the stock pump just does have it.
Old 01-21-2015, 05:41 AM
SF Nick's Avatar
Thanks for the info guys. I purchased the Trail Gear setup. Looking around at the prices of PSC & you just can't beat $250 for everything minus a drill bit, tap, & fluid. I'm gonna run my stock Delphi box & pump for now. I'll upgrade things if this setup doesn't work out.
Old 01-21-2015, 06:03 AM
JE8154's Avatar
the 1.5" ram with the stock pump felt better on road than the 1.75" does with the psc pump. But offroad it's amazing how much better the 1.75" is. Even with the front locked I get the same amount of resistance on the wheel as I do in a parking lot. My only complaint with my current setup is at highway speed it's more sensitive than I would like.
Old 02-15-2015, 09:38 AM
SF Nick's Avatar
I got my Ram installed. I went with the 1.5ram, I'm using a PSC gear box & stock pump. I can turn my tires while siting still but it's not as effortless as what I was hoping for. Is there anyone running a 1.5 ram with a PSC pump & would doing that route give me a little more power? Thanks.
Old 02-15-2015, 01:18 PM
JE8154's Avatar
You'll get more power from a bigger ram. More flow will get you better response. How does your current setup feel at highway speeds?
Quick Reply: Trail Gear Ram Assist
