Truss help
Truss help
I have a 2008 4door with a lot of extra weight on it and NO lift yet. Bumpers winch armor and stuff. I'm looking at getting a truss installed. I like the Artec truss for my D30. I went to an jeep shop around here that has installed some truss's and they told me I would need a good lift so I didn't hit it when I'm flexing. I will be putting on a 2.5 lift at some point. I'm getting in to my axle to sleeve it and c gussets and replace a leaking seal. I wanted to truss it at the same time. But I'm afraid I can't now. Has any one installed a truss with no lift. And if I lift my jeep 2.5 will that be okay? I want to keep my center of gravity low and go to 37s
I wish i wouldn't have put a truss on my front. Mines a different axles but i lost up travel, and ended up a little higher then i wanted. It wasnt drastic but definitely a little bit.
I thought about add the appropriate bump stops if needed. And is having a truss with sleeves worth loosing my up lift? How much up lift did you loose when you you added yours?
Sleeves are cheap and easy and add about 60% strength improvement to the tubes. If you need more beef than that, it's time to step up to a big boy axle.
I don't think it will hit the frame. I run one with 1.5" bumps and the truss isn't even close to hitting the frame. For a DL flip you need a min 3" total bump(bumps plus frame notch).
Compared to a stock JK, you'd need to add a min of 2" of bump stop (might be 3", I forget). If you're running 37s and stock fenders on xyz lift, you're fine as you will need that much bump anyway. If it is stock suspension, you're loosing valuable flex. Sleeves are cheap and easy and add about 60% strength improvement to the tubes. If you need more beef than that, it's time to step up to a big boy axle.
There are many variables, but generally speaking, the truss doesn't work with stock suspension.
To the OP, the best bet is to just call Artec and ask. They're really good about answering your questions.
