Unsure what gears i have
Finally got around to doing this to check. Unfortunately I do have 3.21s. It's surprisingly ballsy for such tall gears.
My 2009 JKU Sahara build sheet says mine came with the 3.73 gears and I'm pretty certain that was standard with the Sahara and auto-trans package back then. Are the 3.21 gears being standard something that changed for the 2012+ 3.6L Sahara auto-trans JKU's?
I'll be moving to 35's some time after my lift is installed, I already know then I'll likely want to go to 5.13's w/lockers and then the real fun ($$$) begins.
From my build sheet:
DJRS - Next Gen. Dana 30 Solid Front Axle
DMEP - 3.73 Axle Ratio
DRZS - Next Gen. Dana 44 HD Rear Axle
DS7S - Conventional Differential Frt Axle
DS8S - Conventional Differential Rear Axle
EGT - 3.8L V6 SMPI Engine
My 2009 JKU Sahara build sheet says mine came with the 3.73 gears and I'm pretty certain that was standard with the Sahara and auto-trans package back then. Are the 3.21 gears being standard something that changed for the 2012+ 3.6L Sahara auto-trans JKU's? I'll be moving to 35's some time after my lift is installed, I already know then I'll likely want to go to 5.13's w/lockers and then the real fun ($$$) begins. From my build sheet: DJRS - Next Gen. Dana 30 Solid Front Axle DMEP - 3.73 Axle Ratio DRZS - Next Gen. Dana 44 HD Rear Axle DS7S - Conventional Differential Frt Axle DS8S - Conventional Differential Rear Axle EGT - 3.8L V6 SMPI Engine
Yeah. 3.21 are standard with 3.73 being an option now.
Maybe since the 2012+ also came with a new auto-trans they decided the 3.21 gears were a better fit for the Sahara's unless you needed the extra towing for the tow package?
Maybe I should go verify my Gears. My build sheet says 3.73, and if they're not, then maybe some replacements are due to me.
