What all parts will swap over from dana 30 to Dana 44?
I'm looking to swap in a rubi front axle into my 12 JKUS. I keep finding just housings for sale on Craigslist and I want to make sure of what all I can reuse. Such as the spindles and rotors/brakes?
Thanks in advance.
Thanks in advance.
The outer shafts can also be re-used, same 32spline on both axles.
How much are you finding the housings for? You can get a new bare housing for a bit under 1k. The locker itself is about 1400, but you might look at Arb or Ox instead of factory.
You should also do a quick search, there have been many threads about an ebay seller building these factory front d44 axles for under 2k, possibly with a choice of gearing.
I bought a brand new rubi front axle from the guy on eBay for $1700 with 4.56 gears. Came with the locker. I only need to swap over the calipers and rotors. I plan to add sleeves and gussets before installing it.
Can you post me a link or pm me the link to this guy on ebay ?
I am doing the same thing and was going to go the eBay route but decided I want to start off right. After adding the extra beef to the stock Rubicon I could drop and extra $1.5K and get a PR or TF. Both solid units with the strength almost that of a D60 for a lot less. If you get a PR you can get all assembled with R&P and locker from Dynatrac and all you need to do is swap over your outer axles, knuckles, hub bearings and brakes. The Teraflex you just get the housing so you need to source all the parts and put it all together or have a shop do it.
$1700 for a stock D44 + $55 for gussets + $120 for sleeves (or $150 for a truss), and you are still under $2000. Toss some LCA skids on and bracket strength isn't an issue. You'll be nearly $3k more for a PR44. You gain nothing for the $3k. You may perceive more peace of mind, but it doesn't really exist.
And don't forget that the ARB lockers are not plug and play. You need a compressor and have to wire all that up and run air lines.
Exactly which parts of a PR44 are almost as strong as a D60? Setting the housing aside for a moment, you have all the same weak parts that the stock D44 has (and most of what a D30 has): ball joints, hubs, R&P, knuckles, etc. Does the housing get closer to a D60 in strength? Sure, it is a lot closer than a stock D44 is, but still a bit of a way off.
Aries 3D Floor Liners Jeep | 4WheelOnline.com
I got these ones for my jeep, and I like them
I dont have any pics on me right now though, sorry!
This isnt exactly a fair assessment. And this is not me trying to sell Pro rocks.
The above takes into account the end user doing all the labor and sticking with stock ball joints. And to say you gain nothing over a stock housing that is sleeved vs a pro rock isn't exactly true also. I have seen plenty of Stock 44's that are sleeved and still break. The pro rock 44 gives you thicker tubes, increase castor , Beefier Brackets and for the extra 3,000 you would also have upgraded ball joints.
Also the extra 3,000 would include RCV shafts and the axle fully assembled.
David
