Sponsored by:
Sponsored by:
What happened here?!!
Old 11-28-2014, 07:19 AM
fultonromero12's Avatar
Default What happened here?!!
After noticing a slight sag in the right side of my jeep I did some investigating. This is what the right rear teraflex leveling puck looked like. I've never seen this happen before. I installed the leveling kit myself and I'm OCD and triple checked the coil was seated well and everything was tight. I do go offroad some mild trails no rocks.
I know it needs replaced. Now the decision is what setup to go with. I'm happy with this 2" leveling kit with my 18/59 coils. What should I replace this with?
Old 11-28-2014, 07:27 AM
Vladimer's Avatar
Wow, I've never actually seen that happen. I started off with the TF BB and wheeled it well, took them out and minus being dirty, still look the same as when I put them in. Possible you have a lot of flex and the coil was unseating slightly and chipping away at the rubber each time it went back up?
Old 11-28-2014, 08:12 AM
Why did you upgrade to? Just ordered a replacement for the time being. Cheapest fix for the moment.
Old 11-28-2014, 08:50 AM
Vladimer's Avatar
That was awhile back. The pucks were not bad and the ride quality was good but the weight of my bumpers, tire carrier and winches made me sag a fair bit. I ended up going with heavy duty old man emu coils front and back (I had a two door) and it brought it up to a perfect height for me with all that weight.
Ended up selling that Jeep and got a 4 door and have 3.5" RK springs in there now.
Old 11-28-2014, 02:39 PM
Biginboca's Avatar
I had a teraflex 1" front spacer disintegrate on me like that. I replaced it with an aluminum spacer and no issues since.
Old 11-28-2014, 02:43 PM
mhockey9090's Avatar
OP what about just picking up a set of 2inch lift coils for the front instead of going with a spacer ?
Old 11-29-2014, 03:04 AM
So you would just add coils to the front and leave the back without anything?
Sent from my iPad using JK-Forum
Old 11-29-2014, 03:48 AM
jadmt's Avatar
I had a front tf spacer fall apart too. I think they are made with recycled plastic pop bottles. Just order a set of Synergy spacers. They look like much more durable material.
Old 11-29-2014, 04:16 AM
kjeeper10's Avatar
I would at least call them up. Give em a chance to explain. I'm sure you'll get a new set of spacers .. Sell them if you want to go a different route.
Old 11-29-2014, 04:23 AM
webejeepin's Avatar
Uhh never seen before like this.
OCD here too, I'd give a call to TF I've reached out to them before very responsive to calls and helpful too.
Quick Reply: What happened here?!!
