Winch and conversion bumper kits
Depending on the winch it can create quite an airflow obstruction. If that's not an issue or you have a lower profile puller in mind, that's my two pennies.
I like my winch as low as possible, but they are some economical bumper options that accommodate a sunken winch mount. Or fab has a stubby for about 400. Of course the China specials can be had for a couple hundred, and are widely available and purchased on eBay and Amazon alike. Have a couple local shops producing quality stuff for under 500, if you can find a local shop that is realistic in their pricing.
Really all the jk bumpers are a brake pressed steel plate bent over twice and trimmed to fit with ends welded on, roughly of course.
I installed mine upside down between the frame rails. Works great.
AMEN
QUOTE="Ampicci1156;4210647"]Thoughts of winches on factory bumpers? And factory conversions bumper kits?[/QUOTE]
AMEN
The JKU is so heavy to start that I am very hesitant to add any extra weight. I installed Rough Country stubby caps, will be installing a Rock Hard winch plate with a Superwinch Talon winch. Extra weight adds stress to the rest of the drivetrain. And if I damage a bumper, they can be had on Craigslist for really cheap.
It mounts to the frame. It is an easy install. I have installed several now and the only issue is rockhard supplies two bolts that are to short. Not sure why they don't supply ones that are 1/4" longer and grade 8 but they are easy to get so I just recommend getting them.
