WTOR Hydro Install Help
Stock they use transmission fluid (I'm guessing because it's cheaper for them to have one less unique fluid in the factory, and it really doesn't matter what you put in, in fact pretty sure you could functionally use water if you wanted to but it'd cause corrosion). I've read that transmission fluid might cause the ram gaskets to go bad sooner but it was just a forum discussion so who knows, I have serious doubts that of all things a ram gasket is going to bad because of transmission fluid.
As for length, my WTOR JK kit came with a 7"x1.5 ram, which would explain why I had to add about a 1/2" shim to get the right length but you're a little short with a 6" length. The "correct" length for a JK to give max steering range while keeping off the steering stops is 6.75", this is what PSC ships.
I asked the owner (Mark) this and he stated Royal Purple, Amsoil, and AcDelco power steering fluid in that order.
This. Remember you are using the stock pump so run the fluid designed for that pump. Psc recommends power steering fluid (swepco I believe) because they use THEIR pump in their kit. WTO does not use a highflow pump because they use the smaller 1.5" ram where psc uses a 1.75" ram that requires their pump. You can also use an off the shelf atf+4 synthetic fluid
thanks for the info, I know on their website they say to use a good synthetic power steering fluid . I'm currently using Valvoline syntec power steering fluid weird thing is I can't seem to find at any part stores now. Oh well maybe need to change to another brand......
West Texas recommends Lucas and it's on the shelf at AutoZone in the nearest town, so that is what I am using. It's inexpensive and easy to get. Besides, there isn't a lot of magic to hydraulic fluid. I sure wouldn't over think it.... no matter who the pump came from.
