Zone Offroad 3" Lift Kit - Page 2
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
  1. #11
    JK Newbie deputydog's Avatar
    Join Date
    Sep 2008
    Location
    Dayton, Ohio
    Posts
    17
    I have pro Copm 8179's 15" x 10" on Pro Comp Xtreme M/T. I attached pics of the tires and kit.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	13235   Click image for larger version.
  2. #12
    JK Junkie robin's Avatar
    Join Date
    May 2007
    Location
    slp. Mexico
    Posts
    3,932
    looks pretty good.
  3. #13
    Join Date
    Aug 2007
    Location
    Hammond Louisiana
    Posts
    15,666
    Deputydog, you may want to install the lift and see how it drives before you do cambolts. I have a 4in superlift on a 4dr and mine drives fine without them. I am planning on getting some adj lowers and didn't want to cut a notch in my ctrl arm brackets, just sayin you may be ok without cutting so that in the future you can get adj arms and not worry about them shifting or having to rebuild your brackets. And they will shift if you off-road, why have an extra worry.
  4. #14
    Join Date
    Sep 2008
    Location
    Dayton, Ohio
    Posts
    17
    Good idea...Thanks for the info because I do plan on the control arms later down the road. The whole "ESP" coming on is my major concern. Did you have any poblems?
  5. #15
    Join Date
    Aug 2007
    Location
    Hammond Louisiana
    Posts
    15,666
    The only prob I have with esp is going to fast on tight cloverleaf on ramps, other than that no esp issues taking reg curves fast or any other normal operating, just the tight on-ramps.
  6. #16
    Join Date
    Apr 2008
    Location
    Ganado, TX
    Posts
    37
    Well did you get the lift on yet? I cant wait for pics!!!!!!!!!!!
  7. #17
    Join Date
    Sep 2008
    Location
    Dayton, Ohio
    Posts
    17
    Ok the lift from Zone products is complete and I could not be happier. It took me and a buddy approx 5 hours to complete with out any iproblems. It looks absolutely great and no "ESP" issues at all. The ride is 10x smoother than factory and the wider stance makes it alot more stable. Below are some pics of the completed project.
    One issue with the 15 inch pro comp 8179. My rear pass caliper was about 1/4 wider than the rest. So the wheel weights were just barley scraping causing a slight squeek. I just took it up on the highway and it worked itself out. If you get these have them put the weights closer the the front then the back of the rim if at all possible or use only 7 gram weight not 14 gram if it can be helped.
    Also, with these 35" tires, I did cut out about a 4" triangle from the plastic piece below the bumper. Not a big issue but it was rubbing on full turns.
    So far I and completeley satisfied with the 3" susp lift from Zone Offroad. It is the best kit for the price and the look is awesome. If you are hesitating because they are the new kid on the block... don't, you won't have any regrets.
    I do have pics as the insall went on. PM if you need any or have any questions.
ID:	13464   Click image for larger version.
ID:	13465   Click image for larger version.
ID:	13466   Click image for larger version.
ID:	13467   Click image for larger version.
  8. #18
    Join Date
    Sep 2008
    Location
    Dayton, Ohio
    Posts
    17
    PS... don't buy the spare tire spacer or the third tail light ext kit, about $100 bucks, you don't need it whith these rims due to the backspacing.... about 3.75. Fits right on.
  9. #19
    JK Enthusiast 2drREDROCK's Avatar
    Join Date
    Jul 2007
    Location
    Surrey,B.C. Canada
    Posts
    455
    Looks good
    2007
    2dr Redrock
    Sahara
    Fully loaded
    Mopar Bugguard
    3" Fabtech lift
    35" Mickey Thompson ATZ
    K&N Cold Air intake
    Fabtech stabilizer
    1 1/2" Hub Centric wheel spacers
    Mopar vent visors
    4:10 Gears
    I LOVE MY JEEP
    coming soon:
    0r-fab tire carrier
    Northridge4x4
  10. #20
    Join Date
    Aug 2008
    Location
    tokyo
    Posts
    248
    it still has that damn rake.
    2k8 Rescue Green jk
    teraflex 2.5 spring lift
    2inch spacers
    RR front bumper and rock rails
    teraflex spare tires relocator
    mygigerry
    piaa lights
    Onboard air
    quick disconnects(via wrench and ratchet)
    other crap
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
