Part out
Old 01-10-2017, 05:47 AM
TheDirtman's Avatar
Default Part out
I have parts for sale.
Pro rock 60's front and rear. 5.13 gears, ARB, 35 Spline, 8x6.5", warn hubs, stub hubs, 68.5 WMS Set up fro front 3 link rear double triangulated 4 link or 3 link and out board coil overs. Roughly 10,000 miles on them. $9500
1.5" wheel adapter for said axles (1 set)
King 2.0 16" travel coil over triple rate $800 for the pair.
King 2.0 14" travel coil over dual rate with compression adjusters. $800 for the pair.
JKS Track bar (series 3) $100
Poison spider HD cross member $100
2.72 transfer case $500
1310 driveshafts (qty 2) 30.5" long $200 each
Ruff Stuff Heim joints for control arms (qty 6) $30 each
Johnny joints for control arms (Qty 2) $30 each
Metal Cloak Joints for control arms (QTY 2) $30 each
17" Moab wheels (4) with worn factory BFG tires free.
I can assist with the axle swap and whatever brackets you want/need for your set up. I will consider trades of factory axles (no dana 30's with 3.21 or3.73), firearms, silver (1 oz sized spot price). Just let me know what you have and the worst I can do is say no.
All Items can be picked up in Reno/Lake Tahoe. I do have a forklift to load axles into truck.
Old 01-10-2017, 05:48 AM
jedg's Avatar
what?! What's happening to your jeep? I HOPE it's for an upgrade? Or have you decided to go to a buggy?
Old 01-10-2017, 08:15 AM
DJ1
Former Member
DJ1's Avatar
Damn!
Old 01-14-2017, 07:18 AM
TheDirtman's Avatar
Just going different direction on the jeep.
Old 02-01-2017, 07:11 AM
TheDirtman's Avatar
Bump for KOTH. I will be there all week if anyone wants me to bring anything down.
Old 02-01-2017, 06:23 PM
Former Vendor
HighSierra4x4's Avatar
Wow it sounds like you had quite the build. If you are getting rid of Dynatracs what are you putting in their place? #HS4x4 wants to know.
Old 02-01-2017, 06:53 PM
Huck271's Avatar
Those shocks seem a little tall for a JK. Where were the 16s mounted?
Old 02-01-2017, 07:25 PM
TheDirtman's Avatar
Pro rock 80 rear and 60 front. Bought a used set with 5.38 gears so I just swapped them both in.
Old 02-01-2017, 07:26 PM
TheDirtman's Avatar
ON the rear had the 14's up front. Now rocking 18" 2.5's all around with some bonus 3" triple bypass at each corner.
Old 02-02-2017, 05:34 AM
Former Vendor
Are you running 44s? I run 40s on a PR80/PR60 in my JKU but I run 12" 2.5s with bypass. I had 14s but the ride height was a little high. With that much shock you must be running big rubber.
Quick Reply: Part out
