4" Lift Question.
4" Lift Question.
Hey all,
I've read a lot of differing opinions about lifting my 2016 Rubicon 4". Some have said this lift kit is good, has all I need, etc ... some are saying it'll destroy my driveshafts, need new drivelines ... those more experienced, can you provide your thoughts on this kit? My plan is this 4" Old Man Emu kit and 35" BFG KM2s.
https://www.quadratec.com/products/16090_0300_07.htm
To me, it looks like it has everything I need?
Not a bad kit theres things i would do different. For 1 scrap the cam bolts for control arms.
Ome uses different rate coils, i would worry that kit would set you at over 5" of lift.
You will need to change front driveshafts or put spacers in the exhaust if you are gonna go off-road. Longer brake lines are a real plus too. I have not heard any good about the cam bolts either.
Way more lift then you need for 35's. Keep it simple and stay around 2" and you will be better off. I would agree with above that you should expect more like 5" out of the OME coils unless you have a real heavy jeep. At that height you should be looking at a full set of control arms, drag link flip, driveshafts, and brake lines.
Take a look at 2.5" lift from MetalCloak or Rock Krawler. Give this a listen for a bunch of info on doing the MetalCloak install
Northwest Jeepcast: 2017 JKU Metalcloak Game Changer installation
For only 35" tires you only need a 2.5" lift. How much off-roading will you be doing. It can be cheap to lift a jeep, but put a little investment into the lift and it'll ride better than stock.
A 4" lift on a 2 door is quite a bit. I'm betting you'd need to at mimimum replace the rear driveshaft and probably either do the Rzeppa joint conversion or replace the front driveshaft too. Like others have said, you'll need the exhaust mod/crossover if you plan to wheel it. I'd recommend different rear control arms too to recenter the axle in the wheel well, otherwise you'll have to cut a lot more of the rubi rail and wheel well. Are you planning to run stock fender flares, cut them or buy aftermarket flares? If you cut or buy aftermarket you could easily do a 2.5" lift and clear 35's. Just for reference. My 2 door is on 2.5" Metalcloak springs, cut stock fenders and I run 37's. I'm a fan of the low lift/big tire look though.
Again, I really appreciate the willingness to help a new guy like myself. Very helpful and much appreciated.
You can get by with the 4.10's. Hell I've been running 35's and 37 sized tires on 3.73 gears for almost the last 4.5 years and am just now regearing to 4.88. Just gusset your C's on your front axle if anything. You'll be fine for awhile.
