Anyone running 110mm
Ok so today i got some king 110mm shocks. I have noticed the front driveshaft is at a crazy angle. So when you pick it up the front end will hop and sometimes it will lock up and wont move at all. Is anyone else having this problem and if so how did you fix it? Also i almost for got this is on my scx10 jk kit.
JK Forum Regional Rep
You have to remove the C-hubs,then grind the housing so you can turn it.You can add a insert inside the housing to add strength,plus gives you to reattach the C-hubs to
