Project 5.3 ls1 in Jeep JK... need help!
Old 11-25-2009, 05:42 AM
  #101
mikesjk's Avatar
Originally Posted by SLeepY_BoY
i guess i still need to buy a few things, im adding maf sensor to the list, btw that cable is perfect im ordering it... im currently working on another project also.. will take pics soon...
I would make sure that the cable works with the gear shifter.
Old 11-25-2009, 04:43 PM
  #102
eljon928's Avatar
keep it coming!!! good work!! my friend put in an ls1 into a tj and it runs like champ!!
Old 11-26-2009, 12:43 AM
  #103
SLeepY_BoY's Avatar
things arnt going so well, after raising the fuel tank in place, we have just realized that it wont fit... i havent seen the problem personally but im going to go today and have a look... the plastic fuel tank is touching the tranny!! thats not good, i guess ill have to see it to know how to fix it, in the mean time any ideas!!!
Old 11-26-2009, 11:54 AM
  #104
SLeepY_BoY's Avatar
here are pics of my problem
Old 11-26-2009, 08:00 PM
  #105
derby911's Avatar
If you can get all the gas out and the fumes You can probably use a heat gun to soften the corner enough to push it in out of the way
Old 11-26-2009, 08:40 PM
  #106
SLeepY_BoY's Avatar
it wont crack? its wortha shot i guess
Old 11-26-2009, 08:46 PM
  #107
Stuka's Avatar
Yeah, you can heat it up and push it in. Its not easy, as the tank is fairly thick. You need to drain it completely, and gett he fumes out (use an air hose stuck inside).
You will need to heat it up a fair amount (heat gun may not be enough), and then use a ball peen hammer or the like (round side) to pound it in.
Your other option, which is far easier. Is to trim the pan. You can easily cut that corner down without any real downsides. Have had to do this in other vehicle engine/tranny swaps before.
You may just have to do both.
Old 11-26-2009, 11:48 PM
  #108
SLeepY_BoY's Avatar
if you guys can show me some pics, or find some links that could help me, that would be great, i need to get this jeep on the road asap.....
Old 11-28-2009, 05:54 AM
  #109
lamar95x4's Avatar
I think if you used a heat gun http://www.harborfreight.com/cpi/cta...emnumber=66098 [in a very well ventilated area] with proper precautions and a body dolly http://www.harborfreight.com/cpi/cta...emnumber=31277 you could easily "massage" it to a sufficient clearance. Just taking the corner off of the pan may not be enough clearance.
Mike
Old 11-29-2009, 01:27 PM
  #110
jkx0778's Avatar
why not just use a fuel cell? you can usually order then in different sizes. a place like - fuel safe - can make custom tanks too.
Quick Reply: Project 5.3 ls1 in Jeep JK... need help!
