Project 5.3 ls1 in Jeep JK... need help!
Old 09-23-2009, 07:24 PM
Schantin's Avatar
Good luck on the build. I'll be watching it closely. I saw the write-up in 4wheel Drive about "Straight to Rediculous", which has a Magnacharged LS2.
There will be a lot of fab work. That build used a custom front subframe for the engine (to include removal of the inner fender wells), and none of the stock dash gauges were retained.
Your big dilemma will be the initial mounting and wiring. Sort that out and you should be good.
BTW, if you have any Q's on the 5.3 (or upgrades for it), PM me. I have over 7 years mod experience on LS engines, to inlude forced induction. (see sig)
Old 09-23-2009, 08:07 PM
SLeepY_BoY's Avatar
Originally Posted by blakes jeep
Eveything on the jk goes threw the pcm's from wipers head lights fog lights turn signals all instermets and even the radio.
how sure are you... about that?, anyways even if i could always keep the jeeps pcm to control the jeep and run the engine as a standalone
Old 09-23-2009, 08:16 PM
Atl JK's Avatar
That'd would probably be your best bet. Especially since you're planning on running forced induction. Pretty much everything on modern vehicles is controlled through the PCM.
Old 09-23-2009, 09:10 PM
Schantin's Avatar
You can do it with a BigStuff3.... but it's expensive. Around $2500. Oh....you can't run the 4L60 as a stand-alone. It's computer controlled. You need either a 700R4 (from a 1993 Chevy) or a TH400. The 700R4 is equivalent to a TH trans with overdrive.....though it isn't as strong for high HP or high torque applications.
Old 09-23-2009, 11:08 PM
SLeepY_BoY's Avatar
i mean im going to run the tranny and the ls1 as a stand alone.... together by the GM pcm... but basicly that the only thing the GM PCM will run.... everything else, will be canceled by HP Tuners
pics of my fuel delievery system
walbro 255 intank
and corvette fuel filter / regulator
More to come
Old 09-24-2009, 03:49 AM
Mystique's Avatar
This is going to be great to watch. Good luck. lots of pictures.
Old 09-24-2009, 12:07 PM
savage's Avatar
Good luck with your project! ill be glad to see how it stacks up against the hemi's.
Old 09-25-2009, 12:31 PM
intenseblu's Avatar
ok this one is one to watch
Old 09-25-2009, 05:46 PM
zook's Avatar
Count me in.
Old 09-25-2009, 09:53 PM
SLeepY_BoY's Avatar
if all parts are here on time build should start on the 3-10-2009, dam shipping really eats from project build time... i cant wait to get to get the build started...
Quick Reply: Project 5.3 ls1 in Jeep JK... need help!
