Headlight Adjustment after a lift?
Old 09-21-2009, 04:01 PM
drgreybow's Avatar
Default Headlight Adjustment after a lift?
I recently did a lift and need to point my headlights down a bit. I've searched for instructions on how to do so, but haven't seen any posts (or write-ups) that give a clear description of how to do it.
Can somebody help me out here? Pics would be great!
Old 09-21-2009, 04:45 PM
JK-Forum Founder
wayoflife's Avatar
you need a torx t-15 driver. you need to make sure it's a stand alone tool and not some kind of universal driver that you can attach bits to. those will be to wide in diameter and will not work. once you have that, here's what you do:
1. park 25 feet away from your garage door or wall
2. place a piece of blue masking tape 3' up
3. turn on your headlights
4. insert your torx t-15 bit into the outside adjusting screw. on the passenger side, this will be located at about the 10 o'clock position and on the driver side, 2 o'clock position. you will also notice that the grille is dimpled a bit to allow easier access there.
5. rotate the torx t-15 driver counter clockwise until you get your lights in the desired position. for a 3"-4" lift, this is typcially about 3 full rotation.
and, that's pretty much it
Old 09-21-2009, 06:22 PM
drgreybow's Avatar
Thanks wayoflife. Now I see what everyone was talking about. I was looking under the hood instead of the front part of the lights themselves. Only problem now is that I don't have a set of torx tools that will fit. I'll have to make a trip to home depot tomorrow I guess.
Old 09-21-2009, 08:42 PM
Atl JK's Avatar
Like mentioned previously, make sure you get a set of torx drivers. The opening it very small and in my experiences only the drivers fit.
Old 09-21-2009, 08:52 PM
So_Cal_Tay_12's Avatar
haha, too easy, looks like i need to do this
Old 09-21-2009, 09:19 PM
JK-Forum Founder
wayoflife's Avatar
if it helps, i went ahead and did a full write-up with pics and it can be seen here:
Jeep JK Wrangler Headlight Adjustment Write-Up
Old 09-22-2009, 06:55 AM
[N]UGE's Avatar
very simple. thanks.
Old 09-22-2009, 07:01 AM
whpony96's Avatar
You dont need to buy the special tools! Just remove the plastic grill do your adjustments then re-install the grill!
Old 09-22-2009, 07:11 AM
JK-Forum Founder
wayoflife's Avatar
nah, the driver is only a couple of bucks and with it, you can make your adjustment in about a minute. assuming that all the plastic screws come out without any problems, removing the grill can still be a pain especially if you have a winch like a warn powerplant - trust me, i speak from experience.
Old 09-23-2009, 06:23 AM
gpb
gpb's Avatar
Huh? What guy doesn't want an excuse to go buy a new tool!?!
Quick Reply: Headlight Adjustment after a lift?
