Headlight Adjustment after a lift?
I recently did a lift and need to point my headlights down a bit. I've searched for instructions on how to do so, but haven't seen any posts (or write-ups) that give a clear description of how to do it.
Can somebody help me out here? Pics would be great!
JK-Forum Founder
you need a torx t-15 driver. you need to make sure it's a stand alone tool and not some kind of universal driver that you can attach bits to. those will be to wide in diameter and will not work. once you have that, here's what you do:
1. park 25 feet away from your garage door or wall
2. place a piece of blue masking tape 3' up
3. turn on your headlights
4. insert your torx t-15 bit into the outside adjusting screw. on the passenger side, this will be located at about the 10 o'clock position and on the driver side, 2 o'clock position. you will also notice that the grille is dimpled a bit to allow easier access there.
5. rotate the torx t-15 driver counter clockwise until you get your lights in the desired position. for a 3"-4" lift, this is typcially about 3 full rotation.
and, that's pretty much it
Thanks wayoflife. Now I see what everyone was talking about. I was looking under the hood instead of the front part of the lights themselves. Only problem now is that I don't have a set of torx tools that will fit. I'll have to make a trip to home depot tomorrow I guess.
JK-Forum Founder
if it helps, i went ahead and did a full write-up with pics and it can be seen here:
Jeep JK Wrangler Headlight Adjustment Write-Up
JK-Forum Founder
nah, the driver is only a couple of bucks and with it, you can make your adjustment in about a minute. assuming that all the plastic screws come out without any problems, removing the grill can still be a pain especially if you have a winch like a warn powerplant - trust me, i speak from experience.
