JK Drag Coefficient?
Old 10-15-2009, 12:41 AM
toymaster's Avatar
Originally Posted by spinlock
You can approximate it, by using the power curve (to the wheels) and equate it to the drag, measure the frontal area and you are on your way.
Yeah, Yeah what he said...that's right...uuuahh
Old 10-15-2009, 12:48 AM
dxbjeep's Avatar
being an aerospace engineering graduate myself, the wrangler is about as bad as it gets regarding vehicles and DC. certainly doesnt compare to a 777
Old 10-15-2009, 02:04 AM
Mark Doiron's Avatar
... Rest assured the 3.8L does not generate enough thrust and lift for air travel.
Then explain your avatar, sir!
Old 10-15-2009, 03:58 AM
07JKX's Avatar
(laminar flow).
i had a laminar flow after I drank too much... or was it luminescent?
Old 10-15-2009, 04:21 AM
RedneckJeep's Avatar
Are you serious? You gotta be on drugs.
Old 10-15-2009, 05:16 AM
tpm152's Avatar
Mech E grad student here. I know the JK is a better coefficient of drag compared to all earlier models (I read an article about this shortly after the JK came out that the slightly swept back grill and windshield compared to the earlier models helped it somewhat). According to Reynolds number (that characterizes the fluid flow regime) the flow becomes turbulent before you even hit 1 mph so think it terms of turbulent flow. If it helps it looks like the SRT-8 grand cherokee is a drag coefficient of 0.39 (which I am sure is much better than the JK) so compared to the 0.55 of the TJ I would say a good estimation of the drag coefficient for the JK would be ~0.5. Finally I would think the drag would be essentially the same for the 2dr and 4dr as the entry and exit profiles of them are identical and the additional skin drag of the extra length of the 4dr is negligible compared to the drag created by flow over the hood and rear of the Jeep.
Hope this helps as I understand how it is having engineering projects and not being able to find accurate info.
Old 10-15-2009, 07:27 AM
CdnJeepDan's Avatar
Maybe buy a scale model?
h ttp://www.allthingsjeep.com/mtr9908708x.html
(Take out the space between the h and the ttp).
Old 10-15-2009, 07:28 AM
Sponsoring Manufacturer
TeraFlex's Avatar
Isn't it in the same range of the broad side of a barn?
Old 10-15-2009, 07:32 AM
This dude doesn't give a damn about drag coefficient. ...and his little DJ is spankin some ASS.
http://www.youtube.com/watch?v=IXyec7Pm9kQ
Old 10-15-2009, 07:45 AM
ClaytonT's Avatar
Can't you just test it by holding up a 4x8 sheet of 3/8" plywood on a windy day?
It's gotta be close...
Quick Reply: JK Drag Coefficient?
